Question about Asrock K7VT2 Motherboard
Monitor problem how to connect my monitor? I need a diferent cable or a card?
  • soltaino Apr 02, 2008
    thanks, I really fix the problem with a new card
    President:
  • 2,351 Answers
Hello soltaino, your board (K7VT2), did not come with a video card. (New). If you have a video card in your PC it was added. I'll need to know the name of the card to advise you regarding a cable to connect to the monitor. My guess is it's like the pictures listed below.
The Asrock does have an AGP 4x video slot. If your board has a video card installed it's connector would connect to a standard VGA connector at both the monitor & at the video card.
Whick looks like this.
The picture above shows a female VGA port, (like on a monitor).
b9662ed.jpg See the bue cable. That's a standard SVGA cable connector.
If you can not connect to the PC you need a new video card, not a new monitor. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3667003&CatId=876
Suggest this card. It has both VGA & DVI connectores.
Best Regards!
Mike
Posted on Apr 02, 2008
The colour keeps changing (somtimes goes pink or purple) have put it on another desktop with a diferent graphics card and the same happens
Check the connection of the cable where it connects to the monitor.
make sure the screws a tight... what you describe is an indication of a bad connection usually caused by a loose cable
Jan 21, 2011 | iiyama AS4316UTC 17" LCD Monitor
I have an older computer and i have a new flatron lg monitor and when i hooked it up it said analog out of range. what should i do?
Did you try pushing the monitor pass it limit of RES?
Did you try changing out the Video card or overclocking it?
Did you change something in the OS driver for Video?
Pretty much that's the cause of why you see that message.
If so , connect a diferent monitor and put your settings back to normal , and then connect LCD again
Thanks
Dec 28, 2009 | Computers & Internet
MY monitor is very distorted.
Try disconnecting and reconnecting the cables. Sometimes this is a cable connection issue.
Mar 20, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
The monitor went black and a new graphics card did not solve the problem. a floating box says check the signal cable. I put a working monitor on the computer and the same floating box appeared.
oh chicki chiki yeyahhh! man u gotta man up and try to install a striperama new card, in diferent socket, or get one of the diagnostics card or ebay or something! punchis punchis!
Feb 24, 2009 | Computers & Internet
K7MNF-64 MB is no longer showing any display even at boot up
You shoould try a different video cable. If this does not work, you should make sure that the video card that you are installing to check are compatible with the system.
Nov 15, 2008 | FIC (51-81677-00) Motherboard
No video.
Try to check your monitor cable.. Is it ok?
Sep 19, 2008 | EliteGroup ECS P4M900T-M2 Socket 775...
Motherboard
check cable pins they may be bend and make sure there is no bad conections or short circuit on the motherboard to the chasis to do a diferent test use a pci video card and plug the monitor into it
Dec 31, 2007 | Intel D845GVSR Motherboard
Cable monitor removal
Hi there, removing the cable monitor has a diferent models and brand. some cable just screwing it by your hand both end. and some are connected built in to the screen, if you have this kind of model, you may need some tools and replacement cable for this. simple remove the screw of the monitor at each corner at the back of the screen and see if there is other screw at the back or bottom. then you can pull up the cover the screen and pick up the cable which is connected usally at the small board behind the picture tube which is the CRT Board. then replace the cable with the new one. TY
Dec 23, 2007 | Dell M990 19" CRT Monitor
Asrock K7VT2 Motherboard Logo
102 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
