Question about Panasonic Workio DP-2330 Printer
Panasonic Workio Dp 2500 problem
I connected the printer ethernet cable to the switch and the switch to the pc, but i cant seem to pick it up on the pc or find the printer or connect to it. It says Additional port information required, the device is of a unknown type and i have to make sure that it is configure correctly. What should i configure? the IP of the printer is 192.168.2.20 and the Ip range of our network is 192.168.1 - 99.
Many thanks
  • Rockafella Apr 02, 2008
    HI our IP range is 192.168.2.1 - 99, i can ping the printer with the 192.168.2.20 address but cant install it or pick it up when adding a printer...
  • Anonymous Apr 09, 2008
    Panasonic Workio DP-2500 (vista)
Change any one of the IP adress to one group..i.e.,change 192.168.2.20(address of Printer) to 192.168.1 to 99 or the the other way round..that would solve your problem...
Posted on Apr 01, 2008
Workio dp 2500 everything is working properly no image on the drum the machine does not report any error
hi just cheq tha scaner lamp is glowing if glowing may you have problem in charge unit or charge crona
thanks
May 13, 2010 | Panasonic Workio DP-2000P Copier
I have been using my printer as photocopier but now I need to print from it also. But have download the driver from the net, but it cant seem to print from connected from my laptop.
may i ask what type of connection did you use? (usb or network)
if it is usb, you may double check if your download link is correct:
panasonic.net/pcc/support/mfp/dp-1820/gdi/download.html
select gdi with installer
select for right OS. that's it
Feb 09, 2010 | Panasonic Workio DP-1820E Copier
Our office recently aquired a Panisonic DP-4530 hoping to use it as a network printer. Much to our dismay none of our computers have serial ports. Is it possible to connect this machine using a USB cable...
I assume you mean "Parallel"? regardless, you can pick up a "Parallel" to "USB" adapter cable at your local electronics store to convert it, and then install it the usual way. Although i'm surprised that there isn't an ethernet port on the machine, because I believe it came standard with the Printer interface option, but if you bought it used it may have been removed.
Hope this helps.
Please rate solution
Jun 16, 2009 | Panasonic Workio DP-4530 Copier
Panasonic Workio DP-2500E cant get to work as printer
is it set up through parellel port or ethernet ? if it is ethernet you need to cofigure tcp\ip port to lpr.
Mar 20, 2009 | Panasonic Workio DP-2500E Copier
Unable to get my Windows 2003 SB server to see Dp-1520P
here are all the latest drivers
http://panasonic.co.jp/pcc/products/en/mfp/download/index.html#DP-1820
can you ping the machine.
do you have a proper ip, subnet mask, gateway,
what happens if you use a cross over cable to connect to it.
Sep 26, 2008 | Panasonic WORKiO DP-1520P All-In-One Laser...
Workio DP 2500
means that the machine needs a good cleaning because it reached so many copies. has to be serviced by a dealer
Sep 23, 2008 | Panasonic Workio DP-2500E Copier
What can I do to fix it ?
What is the problem first? Then maybe a solution..
Jul 21, 2008 | Office Equipment & Supplies
Panasonic Workio DP-2330 Printer Logo
458 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
