I plugged a battery charger for a car in the same port as the freezer and it blew a breaker. Then when I reset the plug and plugged the freezer back in it was making a loud buzzing noise. Currently I am defrosting it.. not sure what to do.
Comments:
Apr 07, 2008
- Yeah... The switch was actually located near the top rack on the right.. once I let it defrost and flipped in back to "noise off" and it is fine now... thank you.
IF YOUR FREEZER HAS A TEMP ALARM, USUALLY LOCATED IN FRONT,BOTTOM, RIGHT CORNER, THE TEMP IS PROBABLY ABOVE THE SAFE TEMP FOR FREEZERS, (10 DEGREES) AND SO THE ALARM WILL SOUND.
THERE SHOULD BE A SWITCH IN FRONT TO SHUT OFF THE ALARM UNTIL THE TEMP GETS BACK DOWN TO ZERO. THEN YOU CAN TURN THE ALARM BACK ON.
IF YOU PLUG IN THE FREEZER AND TURN IT ON, IT SHOULD BE BACK DOWN TO NORMAL TEMP (IF IT IS EMPTY) IN ABOUT 24 HOURS. IF IT ISN'T, YOU HAVE OTHER PROBLEMS. CHECK TO BE SURE THE COMPRESSOR IS RUNNING.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool 19.6 cu. ft. Upright
mdl ev161..ser eww4838694... 4 months old.. it replaced a 10-12 year old upright. problem i have is...
(More)
MDL EV161..SER EWW4838694... 4 months old.. It replaced a 10-12 year old upright. Problem I have is after a month or so the food in the freezer gets coated with frost and I am sure I won't be able to keep food in this freezer longer than a few months. This is the worst freezer we have ever had. Purchased from Menards Indianapolis In. on 07-07-09 for $529.00 .....Any ideas?
I have an old split Philips Whirlpool fridge freezer (18M 50/50). The fridge doesn't seem to be cold...
(More)
I have an old split Philips Whirlpool fridge freezer (18M 50/50). The fridge doesn't seem to be cold enough and ice is forming on the back of the fridge when on 3.5.
Was putting ice cream on top shelf, near controls, and alarm (very loud) came on. Unplugged for...
(More)
Was putting ice cream on top shelf, near controls, and alarm (very loud) came on. Unplugged for over 4 minutes, plugged back in and still continued buzzing.
Reset on outlet pushed that while unplogged and still an alarm. Where's the reset?
Thanks in advance,
Derrick Brown
dwb@wellspringlimited.com>
whirlpool upright 2 door freezer EVL209NBTQ ... freezer is running and making a noise, but food is...
(More)
whirlpool upright 2 door freezer EVL209NBTQ ... freezer is running and making a noise, but food is all defrosted
We've got a 7 cu ft freezer that won't switch off. It is a Malleys 'Tucker Box', a famous old...
(More)
We've got a 7 cu ft freezer that won't switch off. It is a Malleys 'Tucker Box', a famous old Australian freezer. Originally made by whirlpool, I think, then that company taken over by eMail and then they bought out by Electrolux. Model number is 90-375-000
