Question about Viking VSM700 Stand Mixer
Motor Dead During a double batch of cookie dough, my Viking professional 100 watt stand mixer motor stopped and does not turn on anymore. No smoke or smell, just stopped. The motor seems to be completely dead! Is there anything I can do?
  • 1 more comment
  • mainmom8 Apr 01, 2008
    Sorry for the typo...it is a 1000 watt stand mixer (7 qt).
  • cranbot Sep 20, 2008
    I have the same problem except that I wasn't using the mixer. I plugged it in to use it and there is no power. Nada. Nothing. I have had the mixer 4 years and only use it when the batch is too much for my smaller Kitchenaid.
  • pacific1010 Nov 19, 2008
    I have a 800 watt mixer.. used it once to make pudding. the second time i plugged it in and turned it on, then it stopped about 5 seconds into it. now it doesnt turn on at all
I had the same problem the first time I tried to make a small batch of bagel dough (very small!) I had to send it back for repair and wait.....sorry that the news is not better.
Posted on Apr 16, 2009
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
My Viking mixer stand bogs down and stops when it is under a serious load. I sent it to a Viking repair place and they adjusted it but it still bogs down and stops under a load. It is the 1000 watt 7 qt...
The best you can do is to send it right back and make them fix it right... there is nothing you can do with that motor to make it run better..
heatman101
Dec 24, 2010 | Viking VSM700 Stand Mixer
Kitchenaid Heavy Duty 325 stand mixer. Making cookies and now the motor runs but it doesn't turn to mix. PLease help/.
kITCHEN AID ARTISAN 325 WATTS TILTING HEAD PIN CAME OF WHILE MIXING DOUGH. HOW IS THE EASIEST WAY TO INERT PIN BACK OR LINE UP THE HOLES TO INSERT PIN?.
FRANKAMOR
Feb 06, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
It's completely dead - won't turn on. worked fine
You need to remove the motor and find the heat protection fuse on the side of the windings. The fuse is rated at 140 and has a red tip. You might be able to get one from Radio Shack but Viking sells them for $3. Solder into place and take care not to overheat while doing so.
Jun 30, 2009 | Viking VSM700 Stand Mixer
Sunbeam Mixmaster mixer is smoking from the motor or the back are
you fried the motor it is not worth repairing
Dec 08, 2008 | Food Mixers
Loud and throws flour all over
Do you find the motor running too fast at the lowest setting? Then you need to bring it to someone to adjust the low speed setting. If you are preparing double batches you are over loading the mixer and/or using too fast a speed setting to mix. Don't try to double recipes just because the bowl can handle the volume, the motor cannot and will not last very long if stressed mixing dough frequently.
Nov 13, 2008 | Betty Crocker 340 Watts BCF1250 Stand...
Attachments won't turn
most likely a stripped worm gear if the motor still runs but the attachments/planetary gear won't turn.
Did this happen when mixing a big batch of dough or when something fell in the bowl that shouldn't have?
Dec 16, 2007 | KitchenAid K45SS Classic Stand Mixer
K45 started smoking while mixing cookie dough
There is the possibility that if the mixer is 30 years old and it has never been serviced that the gasket around the gear case is leaking oil and in that case it would not be hard to get liquids on the armature or the stator as the gear grease in the transmission is vegetable base grease and it separates into liquids and solid and when the head is tilted up the failed gasket allows the separated oil to leak down and to the rear onto the mixer right onto the motor parts. It maybe nothing more that cleaning out all the old grease and re-packing and adding a new gasket.
Dec 14, 2007 | Food Mixers
Viking VSM700 Stand Mixer Logo
510 people viewed this question
Top Viking Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Viking Food Mixer Expert? Answer questions, earn points and help others
