Question about HP Photosmart C5180 All-In-One InkJet Printer
Ink monitor is lost
Lost the popup message that shows ink levels. How do I get it back? (preferably without re-installing the software).
1. Open "HP Solution Center" (I have it on my desktop)
2. Click on "Help and Support"
3. Under "Tools/Utilities," click on "Status"
4. Click on blue link "View Ink Levels" in lower left of screen.
Posted on May 08, 2008
  • 3 Answers
Try checking to see if your HP Digital Imaging Monitor is loaded & running. If you don't want to reinstall all the software (depending on wether you have broadband DSL) it's about 300Mb for XP or 43Mb for the bare drivers, then your only alternative would be the EWS program (if your going over ethernet), or the printers display screen. In your case I would check the whole software suite, a reinstall might help, but check first to see if all applicable HP program services are loaded & running (using the Task Manager).
Posted on May 04, 2008
HPD4260 unable to check ink levels via printer services
There are 2 ways to fix this.
First one is simple, While the printer is powered on, Disconnect the power cord from the back of printer and wait for 30 seconds and reconnect. You should find the ink level shown when you print.
Second step is is Uninstall the software from software disk re-install again.
Apart from these 2, there is no alternate way to check ink level on Deskjet printers
Regards,
Suhail
May 15, 2012 | HP Deskjet D4260 Printer
How to reset epson T13?
Epson t13 all problem solved EPSON T13 WITHOUT CHIP , INK LEVEL ALWAYS FULL, NO NEED TO RESET INK LEVEL EACH TIME . INK LEVEL AUTO RESET WHEN PRINTER SHUT OFF. INK LEVEL LEVEL ALWAYS SHOW 100 % NO WASTE INK PAD COUNTER MORE NO NEED TO WORRY WHILE PRINTING MORE PRINT JOBS now no more ink cartiledge not recognise problem
Mar 24, 2011 | Epson Printer
I installed an allegedly compatible cartridge and it didn't work. So I fiited Epson cartridge and the printer works but does not monitor the ink levels. In control panel - printers - printing...
Do the process once again but this time remove the printer and unistall the sofftware. Now reinstall the software, then connect the printer as it will be detected as the new hardware and will be installed.
Now the printer ink level must show properly in the display and it must print correctly.
Comment if this tip worked.
Aug 27, 2010 | Epson Stylus D92 InkJet Photo Printer
My epson r220 aont show me the ink levels
goto Epson website to download the Status Monitor software for this model.. or if you have the Driver CD, install the Status Monitor program.. without this, you won't be able to view your ink level..
normally it's in STM folder...
May 30, 2010 | Epson Stylus Photo R220 InkJet Printer
Checking ink levels on my printer
  1. Make sure that the product is turned on and connected to the computer.
  2. Click Start and click Control Panel .
  3. Double-click the Printer and Faxes folder.
  4. Right-click the icon for the product and click Preferences .
  5. Click the Services tab, and then click Service this Device .
  6. The printer Toolbox opens. Click the Estimated Ink Level tab. A graphic showing the estimated ink levels appears. The graphic shows both the color and black ink cartridge with the ink level indicated by the fill inside the cartridge diagram.
Apr 04, 2010 | HP Office Equipment & Supplies
I have a message showing bk tank - code
Its detecting an incorrect ink tank.
The printer is not happy with one of your tanks. Make sure you have PB inks if it is a PG printer.
More probably the job you are printing requires the other black ink tank. Very important to make sure your status monitor is installed correctly, make sure when you send a job that it displays the ink tank levels and not question marks. You should be able to find out roughly how much ink is left through the driver (status monitor) and also what type of black is installed. If you cant, you have not got the 'Status Monitor' installed.
Mar 09, 2010 | Canon imagePROGRAF W6400 InkJet Printer
How to reset ink level warning when refilling?
EASY!!!!: push the cancel button by 6 seconds, this deactivate the ink level sensor.
Dec 15, 2008 | Canon PIXMA MP470 All-in-One Printer
Maintenance tab not showing the level of ink
Have you properly installed the Status Monitor as well as the driver? If not, download SC4344_STM_3aE_MP.exe from:
http://tech.epson.com.au/downloads/product.asp
if this isn't the problem, report back.
Dec 01, 2008 | Epson Stylus C43SX InkJet Printer
Cannot see ink levels
Inkjet printers do not detect ink levels period. An estimate of level is made by the software. It calculates the volume of ink that was dispensed during printing pixel by pixel. If you re-install the software the tally is lost. If you want to convince the software that the cartridges are full then go though the procedure of renewing the cartriges but put the old ones back in. If I were you, I'd completely ignore the displayed levels of ink, its worthless technocrap. Your eyes are the best judge of whether the cartridges need replacing or not when you look at your prints.
Sep 22, 2007 | HP Photosmart C3180 All-In-One InkJet...
Refilled black ink before it ran out-now can use at all
After hours of reading about this I finally found the solution. This will NOT reset your levels but you will be able to print without being told you have empty levels.
Start, Control Panel, then Printers and Faxes.
On the next screen, Right click on your printer then on Printing Preferences. Now select the Advanced tab.
Near the bottom left, you will see more options. Click that and then Appearance. Check NEVER display printing status and make sure under Complete-A-Print, all is unchecked. Click OK at the bottom.
You can print without the stupid messages coming up. Dells printer ink cartridges have a computer chip in them and the refurbished ink does not which causes these error messages telling you your ink cartridges are empty.
Jan 14, 2007 | Dell 924 All-in-One InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
82 people viewed this question
Ben Johnson
