Question about Packard Bell Easy One Silver 2101 Notebook
No Mouse i have a laptop. i turned it on this morning and there was not a cursor on the screen. i run my finger across the touchpad but still nothing happened. i then plugged in a normal computer mouse and again nothing happened. do you have any suggestions to getting my mouse back?
  • 520 Answers
Go to device manager check mouse and pointing devices look for ps/s compatable mouse .check if enabled.go to hp site and download touchpad driver.
http://welcome.hp.com/country/us/en/support.html
type in ur model num in search
Posted on Apr 01, 2008
    Genius:
  • 1,913 Answers
Your keybord is run?
SOURCE:
Clp 288 slim book mouse stopped working after 1 day
First, try an external mouse. If that works, Click start (orb)> select control panel> select hardware and sound> select mouse> your mouse and touchpad software window will open (example: Synaptics is mine) select touchpad tab were you can turn it back on or reset to default as well as adjustments to your devices. Let us know either way if this helps you. Make it a great day!
Dec 26, 2014 | Computers & Internet
Jumping Cursor
Make sure your palm or more than one finger is not covering the touchpad. Laptops manufactured before 2013 did not understand "Multi-touch" on touchpads. Use only one finger on the touchpad and problem should be solved. If it doesnt, the touchpad is damaged. Buy a mouse.
Nov 01, 2013 | Dell Inspiron Computers & Internet
Acer Laptop Help
To get started with this product, complete the following steps.
Turn the laptop on by pressing the Power button located above the keyboard.
Locate the touchpad.
You use the touchpad much like you would use a mouse.
The touchpad controls your cursor.
It responds as you move your finger across its surface.
Move your finger across the touchpad to move the cursor.
Locate the bar below the touchpad.
This bar may be used for selecting and has left and right-click functions that you can use a mouse.
Clicking on the right end of the bar has the same effect as right-clicking with a mouse.
Clicking on the left end of the bar has the same effect as left-clicking with a mouse.
Tapping the touchpad is the same as clicking the left end of the bar.
Use the keyboard like you would use a desktop keyboard.
The only difference is that the keyboard of an Acer laptop is smaller than a regular laptop keyboard.
Click on the Windows icon in the lower left side of the screen to access programs.
Make sure your wireless switch is turned on, if you want to access the Internet.
Then locate a wireless network.
Windows may automatically detect and display a list of available networks.
If that happens, you only have to select the network you wish to access.
If it is not your network, you may need a password if it is security-enabled.
If Windows does not automatically detect a network, open Internet Explorer, and follow the on-screen instructions to connect to a wireless network.
Acer user guides and manuals
http://safemanuals.com/brand-user-guide-instructions-owner-manual/ACER
May 24, 2013 | Acer Aspire Computers & Internet
Acer mouse disassemble ???
The Acer Aspire is a laptop model that has a built-in "mouse pad," also called a "touchpad." The user runs his or her finger across the mouse panel to move the cursor. If your mouse pad no longer responds to your touch, it may be due to a build-up of dirt and grease. Another common problem is having an outdated or damaged mouse pad driver. These problems can be quickly resolved without having to take apart the laptop.
Hold down the "Fn" key, which is found at the bottom left corner of the keyboard. Press the "F7" key once while holding the "Fn" key. Look for a message that says "touchpad enabled." b> Update the Drivers Go to "Start" > "Control Panel" > "System and Maintenance" > "Device Manager." Double-click on "Mice and other pointing devices" to expand the options. Right-click "Synaptics Touchpad" and then click "Search automatically for updated driver software." Wait for the computer to scan and install new drivers. Restart your laptop.
http://www.youtube.com/watch?v=oUyxhcQk6G4 Acer Aspire 5738 7736 Touchpad Mouse Replacement
Jan 30, 2013 | Acer Computers & Internet
While typing a story, the curser will jump backwards, and if I don;t realise it, I am typing between a previous word. Sometimes the cursur disappears from the page completely, and I have to use the mouse...
What's happening is that your finger(s) are touching/dragging across the laptop's TouchPad
while you're typing,
and thus the cursor's position in the document is being randomly reset/repositioned
while you're typing.
Solution: disable your Laptop's TouchPad, and use a mouse for cursor control.
Solution: tape a 3x5 index card over the Touchpad while you're typing.
Solution: type on a computer with a real keyboard, not the chiclet-type keyboard you (and I) are using.
Mar 28, 2011 | Computers & Internet
G netbook cursor moves way too fast but i find no way to slow it down. apparently the solution is not in the help file.
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
Aug 01, 2010 | Sylvania G-Netbook
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
My cursor jumps back to the beginning when i'm trying to type. i'm constantly having to backspace and correct and reset my cursor. any suggestions?
Disable your touchpad if you consistently have this problem.
When you are typing something, and you suddenly touch the touchpad (tapping this touchpad moves the cursor) then your cursor will suddenly change position which then mess up your typing.
If you don'r have an external mouse connected, better be careful not to touch the touchpad. If you have an external mouse, better disable this touchpad.
Mar 03, 2010 | Compaq Presario 700 470024-192 Notebook
Cursor jumps when typing
since you laptop mouse is touchpad. when you starts typing, your finger(hands) touches the touchpad which throw the cursor away. Make sure, while typing your hands does not touch the touchpad of the laptop.
Dec 02, 2009 | HP Compaq Presario V2000 Notebook
Mouse tracking problem on my touchpad
1.See if it still same if you try use USB external mouse?
2.maybe you can try this:
swtch off your laptop, use 99% pure isopropyl alcohol to clean the mousepad carefully, DO NOT spray directly onto mousepad, spray to a cleaning cloth and wipe the the mouse pad carefully.
3. Could be virus
Nov 12, 2008 | Acer TravelMate 4100 Notebook
Packard Bell Easy One Silver 2101 Notebook Logo
194 people viewed this question
Top Packard Bell Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
