Question about LG 42LC2D 42 in. LCD HDTV
Green dots on plasma.
The repair centre has just contacted me, informing me that they are not able to find any green spots on my plasma.
They will just return it to me.
Can it really go away by itself, or will it turn up again in a while?
Is there anything I can do to avoid the problem turning up again?
Thank yoy for any input :o)
Niels Johansen, Denmark
  • Niels Gj?l Johansen
    Niels Gj?l Johansen Apr 05, 2008
    The plasma has just returned...... not as many green sparkles as before, but they are still there.
    The repairshop (LG partner) was not able to see them but made some ajustments anyway.
    Now I've mailed them a photo of the remaining sparkles.
    So it will probably go back again next week :o/
    Champion:
  • 208 Answers
In my experience the diffusion issue can be intermittent and also only be visible on some scenes or even different inputs. If the service center did not see them and did not perform the alignment as put forth by LG then most likely the problem still exists and you will see the dots again.
Posted on Apr 02, 2008
I have a tx-p42x50b when I turned it on nothing no green or red just dead
In fact the TV is Dead. It will be best to contact any service technician in this case, as work with Plasmas are very skilled one. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Aug 14, 2013 | Panasonic Televison & Video
My panasonic plasma has spots of bright colors where they shouldn't be.
If its four years old that is about the average lifespan of one of these sets; a guess would be either voltages drifting or off in power supply or one of the signal boards that processes information is going bad.
Mar 14, 2012 | Panasonic Viera TH-50PZ85U Plasma TV
Hitachi Plasma EDTV has green dots flickering all over screen
that is called diffusion. that can be adjusted out in most cases by adjusting the y sustain pcb but can also be the main pcb, the logic pcb and panel itself but not likely.
Jan 11, 2009 | Hitachi 55HDS69 55 in. Plasma Television
There is a little pink dot on the tv, i think its a pixel that is not working. Is there anyway to fix that?
If this is a projection TV set, it is possible that there is some dirt in the lens system. If the dot is pink, it is most likely the dirt is in the path of the green. In projection tube sets, it is also possible to have a burn spot on the phosphor of a tube.
If your set is a direct view set such as a liquid crystal, or a plasma, or a flat panel, this can also mean a dead pixel on the green. Dead pixels cannot be revived.
Depending on the particular nature of the fault, you will need an experienced TV service tech to service your set.
Jerry G.
Jul 03, 2008 | Televison & Video
Samsung Plasma 720p HDTV hpt5034
If this is a new set, return it for exchange. This is a warranty repair item.
Dan
Mar 19, 2008 | Samsung SPN4235 42 in. Plasma HDTV
LG 42in plasma - Green dots on HDMI channel
The diffusion is slightly out of adjusment. This timing adjustment is difficult and on a single scan LG plasma the proper operation requires voltage settings first, then a scope to finalize the adjustment. I have good luck with this alignment by eye but have had alot of practice. This will require taking the back off and a person with the technical background to set this alignment properly. Sorry no easy fix.
Feb 18, 2008 | LG 42LC2D 42 in. LCD HDTV
Samsung Plasma TV
from the model number you have a 42" set,,the v_set and v_scan voltages need to be set 15vdc lower..this should take care of it,,if not then the plasma panel is bad
Nov 08, 2007 | Samsung HP-R4262 42 in. Plasma Television
Green and Blue spots on screen
Sounds like stuck pixels, you really can't fix that. Do some google research if you are curious what a stuck pixel is.
Oct 30, 2007 | Panasonic PT-50LC13 50" Rear Projection...
LG 42LC2D 42 in. LCD HDTV Logo
158 people viewed this question
Computer Repairing
Computer Repairing
