Question about Dyson DC11 All Floors Bagless Canister Cyclonic Vacuum
The dirt is going into the filter
Instead of going into the see through dirt container, most of the dirt/hair etc. is going directly into the filter and jamming up the machine. My vaccum has wrorked great for 5 years up until now. I washed the filter but the same problem is happening.
    Novelist:
  • 155 Answers
As the air gets sucked through the vacuum cleaner, the dirt is basically thrown out into the container by the spinning air. If the speed that the air is travelling through gets too low, this stops happening and instead it gets sucked through into the filters.
There could be a number of reasons that the air flow has slowed. The most likely is the filters have become blocked over time. Even with regular washing, after 5 years they will not be as efficient as when they were new. I would suggest replacing them (the foam filter and HEPA filter if you have one.)
I would also check that there are no blockages in the main hose, and also give all the component a good banging/brushing to make sure they are nice and clean.
hope this helps,
Matt
Posted on Apr 01, 2008
SOURCE:
I have bought a cordless slimvac It was great for a couple of weeks but for some reason the dirt is not going into the dirt container it is just clogging up the pipes can you help.
Most have simple paper filters that block up fairly quickly.it should all come apart for cleaning without needing screwdrivers etc
Apr 16, 2017 | Vacuums
Why is the dirt collecting around the upper filter instead of going into the dirt container?
The inlet is choked with "dirt". This is especially common if you are cleaning up after a household pet that likes to shed hair.
Jan 05, 2016 | Filter Vacuums
How to empty it
1. Push down on carry handle and
pull dirt container away from unit.
2. Once it is pulled back lift it out.
3. Hold dirt container over trash can and push down on bottom
release lever to release debris.
4. Close bottom cover on the dirt
cup until it snaps shut.
While you have the dirt container out you can also clean the Lifetime HEPA filter. It is on the top of the dirt container.
1. Twist lid to the left to remove lid and filter from
container
2. Remove foam filter from dirt container and dump out
any loose dirt. Wash the foam filter.
3. Remove the HEPA filter by Twist filter handle to the left and
pull out of lid. Wash the Heap filter.
4. Once the filters are thoroughly dry (I recommend set out for 24 hours) then installer filters in lid and thread back on top of the dirt canister.
Before replacing the dirt canister you can also clean the exhaust filter install below the dirt canister on the top vacuum cleaner head.
1. Loosen the exhaust grille by pressing the locking tab, and
remove it.
2. Remove and shake out the exhaust filter and wash it.
Note: Scented filter are not washable.
3. Once the filters are thoroughly dry relace it and snap the
exhaust grill into place.
Replace the dirt container
NOTE: Dirt container will not
align on base if filter is not
aligned properly.
May 15, 2014 | VAX Appliances Vacuums
Vacuum leaves a trail of dirt
There's a small hole in the center front on the bottom by the brush. Its clogged with hair etc. If you stick your finger in there and remove the debris it will work fine. This just happened to mine.
Apr 06, 2012 | Bissell Lift-Off(R) Revolution(R) Turbo...
Dirt/hair not passing through properly
The key to these machines is the velocity of the air flow. If any filter or hose is plugged in the system due to age or sucking something up that was wet, it will slow the air down and it wont 'spin' the debris and then it will get sucked up in the secondary system. Check all of these and if you still have problems then its time to replace filters.
Jun 25, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dirt gets caught up in filter instead of in removable container
That is the problem with the bagless cleaners. The dirt goes through the cup, directly to the filter. There is nothing to keep them seperate. You can try putting a single layer of paper towel against the filter. It will provide a breathable barrier for the dirt but, it will clog too.
Aug 24, 2009 | Bissell 3576 CleanView II Bagless Upright...
Dirt and hairs not going into cylinder
It's not the filter that's the problem.  Air should go first to the cyclones, then to the filter, so the filter catches only those finest dust particles that are not trapped in the cyclones.  The most likely cause of the problem is that the cyclone pack is not properly seated, with the result that at least some of the dirt-bearing air is going directly to the filter rather than passing through the cyclones first.
Apr 18, 2009 | Dyson DC11 All Floors Bagless Canister...
Dyson DC11 All Floors Bagless Canister Cyclonic Vacuum Logo
368 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
