Speakers dont work
My system dont play songs . it gives a msg "Windows Media Player cannot play the file because there is a problem with your sound device. There may not be a sound device installed on your computer, it may be in use by another program, or it may not be functioning properly."
plz help me out ..
    Genius:
  • 1,913 Answers
U need properly sound driver
check your sound chip in motherbord and tell me i give u link to install proper driver
Posted on Apr 01, 2008
Posted on Feb 04, 2009
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Hi, i am very sad becauce my sound dont work,they cant even play any sound. whenever i try to play sound e.g songs it says that "windows media player cannot play the file because there is a problems...
It could be the sound drivers, that could be the cause of the issue. You can start with restoring your system to an earlier time. If that does not resolves the issue then check whether the driver is installed correctly, if not uninstall the driver from the device manager and reinstall it again. It could also be an issue with windows media player. You can also check to see if any other player would also give you the same result or if you do get sound using the other player. You can try realplayer as well.
May 26, 2008 | Computers & Internet
No sound
If it is a desktop then you need to purchase speakers & if a laptop then 90% there would beinbuilt speakers.
Before anything check if the sound is working on the system
Double Click on the speaker icon on the right bottom of the screen>>make sure in none of the mute boxes should be checked>>Now try to play any audio >> this can be tested by playing a song on the system
click the pearl sign on the left bottom>>click programmes>>Click windows media player>>put a cd and try playing it>>Play a file>>
May 25, 2008 | Acer 90.00012.30B Computer Speakers
Inbuilt Speaker not working
Dear Biswaranjan.
the volume control on media player before that there is one button for speaker click on it and sound will come from media player. I think you have muted on media player.
Feb 26, 2008 | Computers & Internet
I can't hear sound from my pc
dear ranga
it seems like u dont have installed u r computers audio driver
so pls install u r audio driver (by a cd or u can also download by www.drivers.com)
i hope u r problem will be solved
regards and best of luck
Feb 11, 2008 | Creative Labs PCWorks Computer Speakers
5.1 Speaker Setup
check if the speakers are working with winamp or any other media player. If yes then install windows media player again. else there might be some problem with your rear speakers. check them out with a hardware service-person. if nothing works, reinstall windows. the default drivers will be loaded and your software problem is solved
Jan 29, 2008 | Audio Players & Recorders
Format error
It's an unsupported file format. Are you trying to play files that were ripped in I-tunes? I-tunes does not make mp3s, it makes m4a files, which are not supported. Make sure the files you put on this player are mp3 files. You can also use wma files, but you will probably need to use Windows Media Player to transfer those files.
Let me know how you get on & shout if you need more help!
Jan 08, 2008 | Delstar DS 31024 MP3 Player
Phillips Gogear 30G Playing problems
The device itself is not faulty. This is Microsoft's fault, not Philips'. Microsoft no longer supports Jukebox. Use Windows Media Player instead.
Some of the songs may have Digital Rights Management (DRM) encoding that the player will not support (once again, Microsoft's fault, not Philips). You can right click on the trouble music file, select "Properties," and select the License or Digital Right tab - look for the msg: This file is not copyright protected. Find out if the songs that CAN'T be transferred have this message. If so, then click on acquire digital rights (or some variant of that phrase). If the files tha CAN'T be transferred DO have Digital rights protection, then you must save the files in a different format that is stripped of DRM encryption.
-Tha Mp3 Doctor
Oct 29, 2007 | Philips GoGear SA178 MP3 Player
Speakers dont work at all
Did you install the audio card drivers?
Oct 29, 2007 | Logitech R-20 Computer Speakers
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
