Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony Trinitron KV 20WS1U
Hi I have been given the above TV and we can only get one channel. How can I programme other channels we have a remote but not instruction booklet!
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Sony Tuner KV-20TS27 loses signal
Either that of your tuner block is acting up. Most Sonys of this production year uses a tuner block that requires 33VDC tuning supply. It has been known for this zener to fail or the capacitor parallel to it. At times, it could just be the tuner block itself.
Should you venture a DIY, it would be to your advantage to have access to a service manual or at the very least a schematic diagram with voltage readings.. It further requires familiarity with electronic components and circuitry, use of a DVM and a soldering iron. Should you be uncomfortable going this route, then perhaps your best bet would be to seek the services of a qualified professional
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 11, 2008
SOURCE: SONY TRINITRON MODELO KV-21XME
Hello pls tell me number of sony kv 21m53 tv H out number i am shihan.....
sshihan@gmail.com
Posted on Aug 07, 2008
Samyfam
  • 379 Answers
SOURCE: No BBC channels available after retuning Sony Trinitron TV
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing as you describe.
If your equipment has the option to delete all currently stored channels (normally in the tuning menu options) then do so and then do a full re-tune.
Sometimes, this solves the problem as the equipment is no longer aware of any previous use of a frequency and just loads every channel it finds.
If this doesnt work, or your equipment doesnt have the option, then there is normally the option soemwhere in the menus to retore the item to "factory defaults/configuration". This will clear all previously stored channels and after a full re-tune your missing chanels should be there. However, any other configuration changes you previously made, e.g picture size, output type (RGB/NSCT/etc), etc will be lost and you'll need to set these again.
NB. some regions of the country have lost some channels temporarily now until after the switch over programme completes at the end of 2012. If you visit the Freeview website, this will tell you if your area is affected.
Posted on Nov 07, 2009
  • 208 Answers
SOURCE: how can i turn on the av channel on a sony trinitron KV-25F1U
Hi, look for a symbol either on the front of the TV or remote that shows a Circle with an arrow pointing into it from the left
Posted on Mar 21, 2010
Testimonial: "thank you so so much, so simple but I dont have an instruction manual. Many, many thanks. Angie"
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-13FS100 - channels cycling
you need to change the control board or the touch buttons
Apr 12, 2008 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinatron has no menu control, can't auto add channels
YOU NEED TO GET INTO THE CONSUMER MENU AND ACTIVATE THE AUTO PROGRAMM MODE. I BELIEVE WALMART CARRIES A UNIVERSAL SONY REMOTE WHICH WILL ALLOW YOU INTO THE MENU.
APGONZO
30 YR SERVICER
Jan 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV
Apparently, channels have to be autoprogrammed first before those buttons will work.
Our TV is 4 years old but we never used the channel buttons bc it was always hooked up to DirecTv thru video input. SO when we disconnected the TV to sell, we thought it was a problem.
Jan 06, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
If its a digital television and has a remoten sensor just buy a universal remote and configure it to your TV.
If it responds then you can search and store the channels you missing.
Thanks
May 07, 2008 | Televison & Video
Channel number in corner
If you have the original remote control, press "display" to get rid off it.
Mar 13, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
27" Sony Trinitron Wega
Hi
Your TV's memmory IC or Main proccessor ic software get problem. You want to re-programm the ic to over come this problem.
Dec 25, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Trinitron KV-20VM40
You can't. Best solution = buy a universal programmable SONY
remote for about 12.00.................................T.
Nov 18, 2007 | Sony KP-44PX3 44" Rear Projection...
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
87 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
