Question about Mitsubishi Color Printer 8000DW Thermal
How Much? how much is the MITSUBISHI COLOR PRINTER 8000DW
  • 88 Answers
The MITSUBISHI CP8000DW is priced at $750.00.
Go to this link: http://www.imagingspectrum.com/Mistubishi-CP8000DW-Digital-Printer-CP8000DW-pr-1820.html
Posted on Apr 01, 2008
I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this. Can anybody help me to find one
Mitsubishi HC1500 DLP Projector Repair Questions ... - Fixya
www.fixya.com > Forum > Multimedia Projectors > Mitsubishi
Recent Mitsubishi HC1500 DLP Projector questions, problems & answers. ... I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this.
I have a mitsubishi hc1500 projector and it made a popping ...
www.fixya.com/.../t5370392-mitsubishi_hc1500_projector_made_poppi...
I have a mitsubishi hc1500 projector, when i went to turn it off it made a loud ..... I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this.
MITSUBISHI HC1500 DLP 720p Home Theater Projector ...
www.newegg.com/Product/Product.aspx?Item...
Newegg
Rating: 5 - ‎22 reviews - ‎$949.99 - ‎Out of stock
MITSUBISHI HC1500 1280 x 720 DLP 720p Home Theater Projector 1600 ANSI Lumens 2500:1. ... If you are a high-definition video enthusiast who's looking for a more affordable way to bring a front-screen projection to your home theater or family room, the Mitsubishi HC1500 projector is
Dec 27, 2014 | Mitsubishi HC1500 DLP Projector
Lines across print
could be dust. try blowing the printer out and clean the thermal print head
Jan 16, 2013 | Mitsubishi Electric CP-3800DW Digital...
THE MITSUBISHI CP8000DW DRIVER IS DISCONTINUED HOW CAN I FIND THE DRIVER?
What OS is your computer running? I found the drivers for supported OS versions here: http://displays.mitsubishielectric.eu/resources/product/CP8000DW . The direct links are listed below. (All are .zip files so you will need to unzip them.)
Mac http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000m_macos.zip .
Win95-98 http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000dw_win95-98.zip .
Win NT and Win2K
http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cpd8000n_wnt4_0.zip .
If you have a newer Windows OS, you can try the compatibility mode. (The NT driver will likely work in XP. If you have Vista or Win7 32-bit OS, it's possible they will work but maybe not. If you have the 64-bit version, the above files will not work directly.) For executable files in Windows, right click on the .exe file and choose properties. Select the Compatibility tab and check Always run this program in the Compatibility Mode. Select the appropriate older version of Windows. Then click Apply. Close the Properties window. Then right click again on the file and choose Run as Administrator (required for Win7 and Vista).
To check if you have the 64-bit OS, click Start > Control Panel > System and Security > System (for Win7). In Vista, the steps may be slightly different. If the version name ends with x64, you have a 64-bit OS. Otherwise, you have the 32-bit version.
If you have a 64-bit OS, you need a 32-bit OS for a work-around. This can be a true second computer, a dual boot system (2 partitions with different OSes loaded), or a virtual computer with an older version of the OS. If you have Windows 7 Pro or Ultimate, you can install a virtual XP computer for free. Go to microsoft.com and download Virtual PC and the XP mode program. Install them in order. Then install your printer under XP as if it were the only computer running. (Note some computer hardware limits may stop you from using this option.) There are other virtual computer programs (VMWare, Parallels). However for the other virtual computer programs or the dual boot or second computer options, you need a licensed copy of the older OS.
I hope this helps.
Oct 03, 2011 | Mitsubishi Color Printer 8000DW Thermal
The picture on my monitor is true color but when i print the picture it has a pinkish tint on them. What is the solution. my cp8000 and 9800 do the same thing.
That is a problem with the Cartridges. Either they have run out of ink, or the type you purchased is poor, so try to check on them.
Dec 14, 2010 | Mitsubishi Color Printer 8000DW Thermal
I hae a 2002 mitsubishi lancer I need wiring
Here is a link that should help you get the wiring colors you asked for. Good luck and hope this helps. http://www.installdr.com/Harnesses/Mitsubishi-Wiring.pdf
Oct 28, 2009 | 2002 Mitsubishi Lancer
Mitsubishi WS65807
The Color Signal on this Model Series travels across three boards before being sent to the CRTs. The 3DYC Board, Signal Board and the Terminal Board. Most likely, the 3DYC Board or the Signal Board is causing the problem. I have had intermittent solder connections on the 3DYC Board to cause no color problems. This Board plugs in and is located on the left front of the Signal Board as you look from the rear of the chassis. If you feel you are not up to the task to work on the set, call a Mitsubishi professional. To find one, call Mitsubishi at 1800-332-2119.
I hope this helps,
Skyassoc
Jul 24, 2009 | Mitsubishi WS-65807 65" Rear Projection...
The color is not working properly on the TV. The red is off.
In discussing with Mitsubishi they had me trouble shoot the cable input line and determined that the color would work in the antenna A and B ports. Mitsubishi believes the scrambling of the cable box is cauing the problem with the normal hook up but I would need to discuss with the cable company. At least I know the color is working properly on the TV.
Dec 26, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi Color Printer 8000DW Thermal Logo
175 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
