Question about Amana SXD524VW Side by Side Refrigerator
Water Filter Hi I have amana SXD524VW side by side and i am trying to find out where the water filter is so i can change it and also what the part number is for the water filter many thanks
Top right hand side of the frigde side. Its the circular looking thing
Posted on Apr 11, 2008
Amana water filter
put bipass plug in filter and buy inline filter
Jan 23, 2014 | Amana SXD524VW Side by Side Refrigerator
We have a Amana refrigerator Model # SXD22SW2 and need to replace the water filter. We don't have the owner's/service manual for the refrigerator and I have looked everywhere on-line, including the Amana...
Removing a water filter from the base grill of your Amana brand refrigerator:
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Oct 13, 2010 | Amana SXD524VW Side by Side Refrigerator
I have an Amana SXD23VL side-by-side refrigerator and the ice cubes are hollow. Why?
Your water presure to the frige is too low. Do you have a reverse osmosis water system hooked up to it?
Sep 01, 2009 | Amana SXD524VW Side by Side Refrigerator
No water to ice maker or despencer
Since you said it was "used" you should check the water filter if so equipped. It could be plugged. Also, and obviously, be sure the water to the unit is turned on.
I'd look for a plugged water filter first. Check the manual for the location (usually near the bottom front of the appliance) first.
Try these steps first.
Apr 04, 2009 | Amana SXD524VW Side by Side Refrigerator
Water dispenser is pouring extremely slow
its the filter. light resets whenever the filter is removed
Jan 21, 2018 | Amana SXD524VW Side by Side Refrigerator
Problem with water bar
You may have a faulty main control board.
Dec 07, 2008 | Amana SXD524VW Side by Side Refrigerator
Leaking
Ebay item number 200261541937 is a repair manual that might help!
Premmy
Oct 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Cleaning the water system
A possible solution is depending on your water source... Chlorine will kill the algae, mold & mildew but the filter blocks chlorine. What we tell people is if you have chlorinated water, remove the filter (a bypass device may be needed depending on the make/model) and run without the filter for a week or so. The chlorine will kill all that stuff and then you can run the filter again. If you don't have chlorinated water you would have to mix a solution of bleach/water in a tank of some type and then use a pump (usually a Sur-Flo RV type pump) to supply the pressure and run a few gallons of chlorinated water through the system (again without filter) then let it sit 24 hours to kill the gunk. After that hook up to normal water supply and flush the system until there is no chlorine smell. The ratios for bleach/water, etc. are available on the internet if you "Google" the process.
Feb 02, 2007 | Amana SXD524VW Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
161 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
