Question about Vivitar 6000AF for Canon TTL Ring Light Flash
Vivitar 6000CAF for Canon EOS doesn't seem to work on my Canon 30D EOS camera?
I bought this ring flash when I had my 10D camera and I think it worked on it? But when I try it on my 30D it doesn't want to flash when I shoot.
  • 3 Answers
A more appropriate product is Suntax DRF14C for Canon 10D, 30D.
http://www.suntax.com.sg/DRF14.html
Posted on Jan 21, 2009
How to mount 67mm thread lens to t4i body only canon
One side of the reverse adapter has a 67mm thread, the other side has a lens mount. Mount it to the camera body as if it were a lens. Bear in mind that it's intended to screw onto the front of a lens and then mounted onto a camera to put the lens onto the camera in a "backward" position.
Dec 16, 2012 | Fotodiox 67mm Filter Thread Macro Reverse...
Need manual
Refer to my answer to your other post.
Dec 02, 2011 | Canon Eos 10d 20d 30d 1v Ae1 A1 Ef Ef-s
Free owners manual ae1 canon film camera
You may download a copy of the AE-1 manual here.
If you have an AE-1 Program, you may download its manual here.
My Canon 10D will not Power On. Do I need the original battery ? Currently I have A battery from my Canon 30D in the 10D.
According to Canon, the battery should work in either camera. Does the battery work in the other camera but not in the 10D?
Oct 01, 2010 | Canon EOS-10D Digital Camera
On my Eos 30D the pop up flash refuses to pop up any more. It seems to be seriously jammed and there is no response to the operating button
Typically this is caused when the spring either breaks, or more likely, slips off the connector.
You can gently grab the flash between your thumb and index finger with one hand and gently lift it as you press the pop-up flash button. It may take a couple times to get it up. If this works and it will not stay up, then it is the spring, otherwise it is the latch that is not being activated. Either way, these are not user servicable parts. Both of these are easy fixes with inexpensive parts, so do not hesitate to take it or send it to an authorized Canon service center.
Hope this helps,
-Tor
Jan 02, 2010 | Canon EOS 30D Digital Camera with 18-55mm...
I have a canon ds6031 eos 10d. When I turn the camera on the view screen does not show what your pointing at. Is this normal?
Yes, it is normal. This is a reasonably old DSLR, and it's designed for you to look through the viewfinder (it's more accurate anyway as it's looking through the lens). You'll find if you keep one hand under the lens and one hand on the shutter, it'll feel quite comfortable to look through the viewfinder.
You can still view photos you've taken after you've taken them though.
Aug 31, 2009 | Canon EOS 10D 35mm SLR Camera
Shot numbering system not working
Menu>File Numbering (I think it's called ), set it to auto reset, should do the trick. Otherwise, format your card and set it to auto reset.
May 16, 2009 | Canon EOS 10D 35mm SLR Camera
Vivitar 636AF Flashgun
I do have the same unit that I am currently using on a EOS 10D. It works fine for me. It lso operates on my EOS 350D but does not flash off quite bright enough on this camera in very low light.The unit was previously paired with a canon EOS 5 film. You can contact me at a.blast@rocketmail.com for required information.
Aug 31, 2008 | Cameras
Canon EOS 30D SLR Will Not Turn On...
I seem to recall hearing that the power switch can be a problem on the 30D .. I'm not going to suggest you take it apart to clean the contacts .. better go to a Canon Dealer I think ..
Mar 31, 2008 | Canon EOS 30D Body Only Digital Camera
Vivitar 6000AF for Canon TTL Ring Light Flash Logo
183 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
