Question about Toshiba Satellite 1405-S151 Notebook
My laptop problem
It doesn't let me anything. The blue windows doesn't show up. It looks like it will then goes completely black, but its still running. Its very confusing.
  • 7 more comments
  • Keidelberg Apr 01, 2008
    It doesn't do any of that, When I turn it on Toshiba emblem appears then fades, then a marker appears and blinks in the upper left for like a second then that notice saying Windows didn't start successfully comes on.
    HELP I have the system setup but I don't know what to look for
    It says the CD-ROM is Secondary IDE(170H/IRQ15)
    Oh no. I don't have the Windows cd. I couldn't change it the secondary. Now I can't get back on to the setup.... I don't know how ya'll do it. Its hard.
    I got these icons on the bottom of the toshiba name and its highlighted on the bottom of each one. Last time I went to the hard drive looking one and hit enter and it gave me the setup screen. Now, its not doing it anymore.
  • Anonymous Oct 11, 2008
    DEAD TOSHIBA SATELLITE LAPTOP 1405, WON'T TURN ON WHEN PRESSING POWER BUTTON....NOTHING HAPPENS, HAS ANYONE GOT AND IDEAS THAT WOULD HELP ME GET THIS LAPTOP UP AND RUNNING? THANK YOU IN ADVANCE FOR ANY HELP, YOURS TRULY, TONY.
  • Karen Valentine
    Karen Valentine Dec 12, 2008
    I have same problem: power supply light comes on, ON light comes on, but no sound from the hard drive and the scree stays black. Worked fine 3 days ago.
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Secondary to your hard drvive? If it's secondary to your hard make it the primary. It has to boot the cd drive before the hard drive. Once you have it so it boots to the cd drive before the hard drive, Save and exit. You should then see it on the screen trying to boot from the cd drive. You'll at least see the cd drive light flash. I don't think I ever found out from you what software we'd be using. I had asked you if you have your Windows cd? I hope so.
  • Jeffrey Pemberton
    OK. Maybe I didn't describe well enough what you might be able to try. I didn't want you to let it get anywhere close to Windows. Boot the computer and as soon as you see it say something like enter (F2) or (Delete) to enter setup, do it. It comes up quick and then goes away so be ready for it. First check to make sure it says your cd drive is set to bootable. Then make sure it says your boot sequence is set with the cd drive ( it will probably have the actual model # of your cd drive) to boot BEFORE your hard drive. If you get it to do that, make sure you save and exit. Usually F10 but look on the menu at the top and use that just to be sure. Let me know if you are able to get that far. From now on we're going to work off of this post so when you reply just add a comment and the system will let me know. I'll be waiting to see how it goes.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 168 Answers
You need to repair your HDD. you can use a program called spinrite to do this. you can DL it here.
burn to disk
place in drive and bootup.
follow directions and use repair option 5.
Let it run, uninterrupted until it finishes.
when it has finished, remove disk and reboot
Posted on Sep 13, 2009
SOURCE:
Black screen!
Does you have Windows 8 Installed?
If Yes, then you installed a cracked version of Windows 8 which caused the problem. Buy The Original One which will solve the problem
Or Else Please Mention The Device Name and Specs You have problem with.
May 06, 2013 | Computers & Internet
Starting Windows
In that case, I would reinstall Windows. Something must corrupted in windows. Do you have your OEM Windows disk with you?
Sep 06, 2012 | Dell XPS M1530 Laptop
Does anyone know why my mic doesn't work and my desktop background doesn't show?
If you have Windows 7 Starter then you are limited on changing the background.
Jun 09, 2012 | Computers & Internet
Acer 5536 boots up goes to screen to select safe mode, tried both modes but after the selection screen goes blank with a little loading circle but goe sno further, no log in screen or anything, please help
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Nov 20, 2010 | Acer Aspire 5500 5570-2609 Laptop
On Startup of my Panasonic CF52, It shows the blue Panasonic screen, then the windows loading screen, then it goes into a bright gray colored screen. It doesnt do anything more. Tried to restart and hit F8...
This is usually a problem associated with NOD32 or Cisco software conflicting with drivers or other software. If you can get past the grey screen even once, uninstall the software and reboot. If you can't get past the grey screen at all, then you might have to completely reinstall windows :(.
I'd look for professional hands-on help in this case if you're not comfortable doing this.
Dec 06, 2009 | Panasonic Toughbook CF-51 Notebook
Vista basic is stuck on update 3 of 3
According to your issue the windows logon screen gets stuck on update 3 of 3 it seems to me you were trying to perform windows update and now the updates are not installed properly in your system due to which you system stuck in such kind of cases you have to perform system restore to uninstall the updates and for that we need windows vista basic dvd in order to get the steps to perform system restore follow the link bellow :
http://vistahomebasic.windowsreinstall.com/repairsystemrestore/repairsystemrestore.htm
Regards,
Om
Oct 16, 2009 | Computers & Internet
Uploading windows vista upgrades command was to restart system for changes to take effect. On restart screen went blue and showed Tech info *** STOP: 0x0000C1F5 (0x00000000, 0x00000000, 0x000000000,...
Press F8 continuously while starting the computer. When black screen appears eventually (right before Windows loads), choose Last Known Good Configuration.
Aug 06, 2009 | HP Computers & Internet
My laptop has a blue then black screen after start-up
Press F8 when you laptop starts. Go to safe mode. Scan and remove virus in safemode. Try and restart your laptop when completed.
Jan 09, 2009 | HP Pavilion dv9000z Notebook
The laptop doesn't boot up always.
I would try the following:
1. Remove the battery completely. If the computer boots properly several times in a row, then the battery may be causing the power supply to do strange things.
2. If you have experience removing laptop components, try removing the hard drive. Because you say the screen goes black (I assume the system powers off) sometimes after the HP logo, I doubt its Windows or a software issue.
3. If HP has a diagnostic CD you can boot to, try that.
4. It may be the power supply acting up. If it charges the battery, and if you can boot to Windows with the battery, try getting a new power supply.
5. Otherwise, it may be the motherboard of the laptop.
Nov 28, 2008 | Computers & Internet
Westinghouse LCM22W2 shows a display then turns off after half a second
I have the same problem and have traced it down to a potential power supply issue.  I bought mine at Best Buy in '06 and was told today that they will test the power supply for free.  It may range from $50.00 to $100.00 depending on where you can get it.  This does not include labor for those not qualified to work with electronics.  Hope this helps you.
Aug 13, 2008 | Westinghouse LCM-22w2 Television
Toshiba Satellite 1405-S151 Notebook Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
