Question about Bushnell NorthStar Goto 100mm 788840 Maksutov-Cassegrain Compact Telescopes
Computer control and pointing with NorthStar Goto & Autostar
I'd like to use my astro-software to point my telescope to a particilar star, to be able to make long exposures with my Deep Sky Imager CCD from Meade. I was told by the reseller, that the right 4-pin connector on the Goto handset is the com port which can be connected to the Meade autostar suite. But this apparently doesn't work. I'd really appreciate if someone could suggest me what software can be used to control my telescope from PC, which way it could be connected to Autostar suite from meade, or at least what is the low level communication protocol of the Goto telescope computer, so that I can program the PC/telescope communication and pointing myself.
Many thanks! Vojtech.Petracek@cern.ch
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Your reseller is correct. The wire (Meade cable #505) goes from an RS232 serial port on PC to a 4pin RJ plug. This plugs into the 2nd socket on the bottom of an Autostar 497 handset, the other socket being used for the curly lead to the telescope. So it goes PC to Autostar to telescope.
A common error is to try plugging the serial wire into an "AUX" ort on the telescope control panel - same connector. Not only does this not work, it can cause a lot of damage.
Wired like this you can control the scope from Meade's Autostar Suite (or many other planetarium softwares). You can also update the Autostar software to the latest 2009 version.
What else can go wrong? Well, many people want to control from a laptop, and modern ones don't have RS232 serial ports. Then you need a USB-to-serial convertor dongle, which effectively add a serial port to a laptop. But they often give it a very high port number (eg COM17) that the planetarium software does not find. Use Control Panel to reset the USB-serial-port to COM 1, 2, 3 or 4 and all should be well. But it can be a right fiddle!
Posted on Aug 15, 2009
Trying to install Autostar Suite. At the point where it is updating system configeration. Just keeps on going and going and going?
Did you get the latest version off of the Meade web site here:
http://www.meade.com/support/AutostarSuiteWebEdition55.exe
Try it--
Mar 01, 2011 | Meade Autostar Suite Autostar Suite...
I have a bushnell northstar 78-8831 and need to know how to reset the telescope. when in align earth mode it asks me to align star 2, skipping over star 1.
This scope has many goto issues. For one there is no way to reset the controller or to reload the firmware inside the hand controller. The firmware is probably corrupted.
You can contact their repair and support web site here:
http://www.opticsplanet.net/bushnell-warranty.html
Aug 10, 2010 | Bushnell NorthStar 78-8831 (525 x 76mm)...
I can not get my Telescope to focus so a picture appears!
You should read the manual - available in the customer service section at meade.com. This is s 'D'eep 'S'pace 'I'mager, so it is geared for faint objects using long exposures (30 seconds and longer). Focus by locating a bright star in the camera, and adjust the telescope focus control for smallest star image. Then move to object wanted to photograph, and begin the long exposures.
Mar 15, 2010 | Meade Autostar Suite Autostar Suite...
I have a Meade ETX model M telescope. I need to
Meade "might" sell you the replacement part. But most likely they will want you to return the scope for repairs.
Call them:
http://www.meade.com/support/index.html
Feb 10, 2010 | Meade ETX-105PE Astro Telescope Premier...
Can't view anything.
point it at sunset the oppisite way from the sun
Dec 27, 2008 | Bushnell NorthStar 675x4.5'' GoTo...
Autostar 497 freezes
When warm and indoors (!) connect Autostar to scope and by serial lead to a PC, allow Meade Autostar suite to update the Autostar Firmware to the latest version (2009!!)
Frome www.meade.com/support/auto.html :
How To Upgrade Your Handbox
To upgrade your Autostar first click on the link below to download the Autostar Update (ASU) Client Application for Windows. If your web browser allows you to open the installation file, you may choose that option when prompted. Otherwise, just save the install file to your local hard disk drive. When downloading is complete, double click on the saved file to start the installation. Follow the instructions provided to install Autostar Update (ASU) on your machine. When installation is complete, start ASU by selecting "Start Menu" -> "Programs" -> "Meade Inst" -> "ASU". If you have an active Internet connection and your telescope with Autostar is connected using the appropriate cable as listed above, ASU will detect and install the correct Autostar code directly from Meade's web site via the "Upgrade Autostar Software Now" button.
Autostar Update
Autostar Update is an application that functions to transfer the event files and software updates from your computer, through the serial port, USB or Connector Cable Set depending on your telescope model. The Autostar Update application is available as a stand-alone client application for Windows. The most recent versions of AutoStar Update automatically check for the newest versions of the AutoStar Updater and download it if necessary. It is critical that you use the most recent AutoStar Updater to ensure that you get the proper software updates for your system.
06/02/09 Autostar Update (ASU) Client Application for Windows, Version 5.6 (1,654 KB). This is the latest Autostar Update. Rev. 5.6 is compatible with the ETX-LS and #497EP Hand Controllers. This version is compatible with all versions of AutoStar II and #497 AutoStar computer controllers. This installation will automatically update the Update Client Application in AutoStar Suite™ Software. If you have previously installed the Autostar Update (ASU) Client Application for Windows, Uninstall the old version before installing this new version. 07/27/09 #497 AutoStar hand controller software update. Version 5BE2 (1,039 KB).
General update. Fixes many known bugs. Real time clock corrections. LXD75 polar alignment. Various LX90 pointing and tracking fixes. Adds new magnetic/true north alignment.
REQUIRES VERSION 5.6 AUTOSTAR UPDATER.
Jan 17, 2008 | Meade Autostar Suite Autostar Suite...
Aiming with the computer
i hav the exact same problem with my bushnell 100 mm makstovut cassgrain check my problem and see if the solution for it works cuz for me it isn't right now.
Aug 09, 2007 | Bushnell NorthStar 78-8890 (300 x 90mm)...
Bushnell NorthStar Goto 100mm 788840 Maksutov-Cassegrain Compact Telescopes Logo
566 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
