Question about Baby Gear
Where do I fill gearoil on a ford escort diesei 1995?
Can't find out how to fill gearoil on my ford escort. can you help me??
    Problem Solver:
  • 13 Answers
If the oil is for the differential , there should be a 1/2 inch pipe plug with either a square head or a squaresocket indentation on either the back or the side of the main case. simply remove it and pour oil in as needed. most manufacturerers specify that the level should be about 1/2 inch below the lip of the filler hole. the same instructions apply to standard transmissions but the filler plug can be a little difficult to find.
Posted on Apr 01, 2008
SOURCE:
Check trans fluid on 94 Ford Escort 5 spd manual trans
Fillplugs on the side of trans. Gearoil need to b level w bottom of plug. Not checd unless u hava leak. Garage or lubechange will inspect. If not shiftn then gearsworn..needajust or clutchproblm
Apr 26, 2018 | Ford Cars & Trucks
In what order do the spark plug wires go on a 95 1.9 escort lx
1995 Ford Escort 1.9 liter SOHC L4
Hope this helps (remember to rate this answer).
Nov 22, 2010 | 1995 Ford Escort
Where do I fill the power steering on a 1995 ford escort
should be on the left side of engine compartment or up by the strut tower
Sep 06, 2010 | 1995 Ford Escort
Replacing transmission fluid in standard
The manual transmission in the Ford Escort uses transmission fluid, it is checked and filled in the same hole. That hole is where the speedometer cable is hooked up to the transmission. Remove the speedometer cable, set aside, then remove the locking bolt that holds the speedometer drive unit in place. Pull up on the drive unit and it will come out, look on the side of the drive unit and you will see the level indicator line for full and add. Fill as needed and reinstall the drive unit and cable. Hope this helps, let me know.
May 02, 2010 | 1995 Ford Escort
New Battery still no power
Check your Main fuses. Use a test light.
Feb 06, 2010 | 1995 Ford Escort
How do i refill a manual ford escort 9.1 L transmission
You can check and fill your transmission oil level by removing the speedometer drive unit located at the left top. Remove the cable by removing the clip that hold it, then undo the bolt that holds the clamp down, when you remove the actual drive unit it has a level indicator on it. The oil is Ford Mercon Automatic transmission Oil. Let me know if this helps. Also if you need to add oil, you should find the leak and stop it first.
Aug 27, 2009 | 1995 Ford Escort
1995 ford escort engine just quit timing belt is
Check out my tips and tricks on my profile page for Engine with starting problems, I think that you help you find your problem. Hope this helps, let me know.
May 16, 2009 | 1995 Ford Escort
1995 ford escort clutch
it could be the slave cylinder.throw out bearing.or press plate.
Feb 24, 2009 | 1995 Ford Escort
1995 ford escort lx fan relay locations
right hand side under bonnet on the wing or at the back by the battery depending on model build
Nov 10, 2008 | 1995 Ford Escort
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Marvin
Marvin
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
