Dell M992 19" CRT Monitor Logo
Posted on May 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I turn on my monitor display coming but after 5 second power led blink and display has gon i think its power suply is drop
Anonymous
Level 2:
Guru:
  • Expert 214 Answers
  • Posted on May 18, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
214
Questions
0
Helped
71700
Points
542
This must be a electricity prob you should voltage stabilizer
1helpful
I have a Polaroid 42" TLX-04244B. When turning the power on the polaroid logo comes on for a sec. then screen goes black with the blue power LED staying solid. Im pretty sure the power suply board isnt...
The Inverter is trying to produce the high voltage to light the backlight. It looks like it cannot hold the charge to maintain the high voltage level in order for it to stay on - you get a momentary display at initial power-up thus see the logo. Replace the Inverter board.
My pioneer pdp-505pg tv won't turn on with a pdp-R06xe media receiver. I changed the power supply but it still clicks on and then clicks off and the red led blinks twice every 3 seconds. Is it the power...
Hi! I have the same problem, did you solved it? I'm from Brazil, and i have the same plasma display, the customer suport of here, sayed that the problem is the power suply board. I saw that you changed the power suply, where did you found it? I didn't found it here, and i will travel to USA.
Thanks!
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
When I press the power button, caps lock, scroll lock, num lock, power led and hard disk led blink in every 5 seconds
they continue to blink every 5 seconds until you turn it off? It should blink all lights upon powering on but then remain off,
43helpful
6answers
LG 700E monitor's power LED blinking continueously, no display
LG 700E monitor's power LED blinking continueously, no displaySolution.............
3helpful
4answers
My studioworks 500G monitor LED blinking with twise colour(Green and Amber)and no display.
1. LOT problem.
2. Horizontal transistor bad.
3. Dry points in neck board, horizontal section.
4. transformer output capacitors problem.
5. IRF 630 ( lot supply fet )
1helpful
2answers
LCD blank screen, blink white
blank_page Use a reset sequence on the monitor-
1. turn off monitor
2. unplug power
3. plug power back in, holding down the last button on the left, then push the power button to turn back on and off three times, holding on the third try until it comes on- hold for ten seconds and release; the monitor should work again
3answers
Computer won't turn on
hi
check your power cable , eathing. smps check *********** bord dont touch the cabinet.i think u have motherbord grounding or your power suply of pc has pro.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
