Question about Hitachi ED-X3450 ED-X3450 PROJECTOR Multimedia Projector
Upside down image!
One of our teachers managed to turn the projected image upside down on a classroom whiteboard. On the menu route, she did this through Reset - Reset. To reverse this we can get to Reset & then the Reset/Cancel option, but can only select Cancel. At the moment she can only teach by getting the children to do handstands. Help!
  • 563 Answers
Hi there
I just drew the users manual and you should do the following:
Go into the setup menu and choose mirror - then just scroll left or right on the mirror and your image will change as you do this.
Posted on Apr 01, 2008
What's the feature of an interactive whiteboard
Interactive whiteboards are mainly used to improve quality of the education in classrooms. The use of interactive whiteboard allows instructor to alter the different information present in the board which can even be copied and transferred to the next slide. The data that is present in the board can be clicked on, moved, copied and analyzed. The interactive whiteboard also allows the teacher to write like the any other whiteboard but it also turns the handwritten notes into texts which can be later referred to at any moment of urgency.
Please read the following tutorial to know some features of interactive whiteboards.
https://www.eztalks.com/whiteboard/features-of-interactive-whiteboard.html
Jun 07, 2017 | The Computers & Internet
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar. http://service.us.panasonic.com/OPERMANPDF/PTLM1U.PDF
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
Hello, PJ452 project image turned upside down. How do i turn it back
At the menu you'll see a place called Projection. You can turn it upside from there...
Mar 02, 2010 | ViewSonic PJ452 LCD Projector
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
Picture is upside down on screen
go into the menu using either your remote or the button on the projector itself. At the top are several options i.e. "picture" scr-adj. Click over to the right ONCE to "SCR-ADJ" this stands for source adjust. Then look for something called like PRJ mode (projection mode) This tells the projector which direction to display the image so that incase you want to hang it from the ceiling upside down you can. Click down to that menu option. You will then have to click over to the right in order to see your options. If you are using it hanging on a ceiling you want it to say "ceiling front" if it is merely sitting on a cart or a shelf just put it on "front".
Good luck.
Aug 12, 2008 | Sharp XR-10X Multimedia Projector
Upside Down Image
Hi there
Go into the Menu - you'll see a subfolder that either reads : Flip image or Mirror.
Go into this subfolder and change the image. If it doesn't work or you still can't find it notify me and I'll draw the user's manual and mail post you the exact steps.
Apr 01, 2008 | Hitachi ED-X3450 ED-X3450 PROJECTOR...
The picture become upside down
You need to change it to front/ceiling in the menu function of the projector.
Oct 03, 2007 | Epson PowerLite 62c Multimedia Projector
Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Feb 11, 2007 | Mitsubishi X490U Multimedia Projector
Hitachi ED-X3450 ED-X3450 PROJECTOR Multimedia Projector Logo
646 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
