Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Lens error, restart camera lens got pushed in
Lens error, restart camera\r\nlens got pushed in
    President:
  • 1,382 Answers
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Posted on May 18, 2010
SOURCE:
About 2-3 months ago my camera suddenly said lens
If it says lens error all you have to do is try pushing the lens back in. If that doesnt work, sorry! lol =(
Oct 10, 2009 | Canon PowerShot A710 IS Digital Camera
Ny power shot camera SX100IS says lenserror, restart camera. How do I fix this problem
Aug 16, 2009 | Canon PowerShot SX100 IS Digital Camera
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Mar 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens error. Restart camera.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 07, 2009 | Canon PowerShot A720 IS Digital Camera
i had the the same lens error restart camera problem for almost a month.  If you haven't already, try restarting the camera with the sd1000 in the view pictures setting.  This may allow the lens to retract into position. Next, with the lens extracted, try looking down on the camera from the top to see if the lens is angled downward in any way.  If it is, this means it is jammed into place on one side.  Simply use your fingers to slightly push the lens into proper position.  If you hear a pop, you should be in business! hope this helps!
Jan 22, 2009 | Canon PowerShot SD1000 Digital Camera
Try to unstick the lens by gently pushing it in or pulling it out a little bit. IF that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Dec 08, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens Error, Restart
Nikon System error help????
Sep 05, 2008 | Nikon COOLPIX L12 Digital Camera
Cannon Power shot SD630 Lens Problem
I had the same problem, tried different things but this is what worked.
I put the camera flat on its "back" (screen down, lens up). Looking down at the lens I could see that it was slightly off center. I pushed the lens towards the center and down, forcing it to close. Once it was centered I was able to turn it on and off no problem.
Sep 30, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
395 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
