Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Slow my computer is very slow in start up and shutdown
  • jimrider2005 Jan 01, 2009
    upgrade my operating system
  • Marty marty May 11, 2010
    have you scandisked and defragged hard drive lately? it should be done monthly
  • 85 Answers
Clean your pc by disk error checking, disk defragment, and delete all temprory files...
then go to srart-run-type msconfig in startup tab then uncheck all check marks..
and for fast shuting down computer follow these steps:-
( quickliy shutdown computer without close application)
‘HKEY_CURRENT_USER\Control Panel\Desktop
’Select ‘WaitToKillAppTimeout’>
right click and select ‘Modify’>
change the value to ‘1000'>click ‘ok’>
now select ‘HungAppTimeout’>
right click and select ‘Modify’>change the value to ‘1000'>
click ‘ok’>
now find HKEY_USERS\.DEFAULT\Control Panel\Desktop’>select ‘WaitToKillAppTimeout’>
right click and select ‘Modify’>Change the value to "1000">
click ‘ok’>Now find ‘HKEY_LOCAL_MACHINE\System\CurrentContro...
‘WaitToKillServiceTimeout’>right click and select ‘Modify’>change the value to ‘1000'>click ‘ok’
The best earn money site..plz signup free
(Join now and receive a $0.05 Sign-up Bonus) on it........
Posted on Dec 23, 2008
  • 813 Answers
Posted on Apr 01, 2008
  • 88 Answers
What operating system are you using?
Why is my computer so slow and especially for games?
press ctrl+delete 1 select task monitor to see what prosses are running
or press ctrl+delete 2 and shut down + force shutdown.
Feb 01, 2013 | Acer Aspire One PC Notebook
Steps to improve the shutdown times.
Start Registry Editor and navigate to the following key:
[HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management] Set ClearPageFileAtShutdown value to 0
Or, using Group Policy Editor [for Windows XP Professional]
Click Start, Run and type Secpol.msc
Click Local Policies | Security Options
In the right-pane, set Shutdown: Clear virtual memory pagefile to Disabled
However, this setting is not the only cause for slow shutdowns. Non-responsive programs and Services also contribute to slow shutdowns. If the problem is seen recently after installing a third-party driver or software, try a System Restore rollback to see if that resolves the slow shutdown problem.
on Mar 09, 2010 | Computers & Internet
Laptop will not shutdown
Remove the battery and unplug it from the wall. Try holding down the power button for about 8 seconds it should shut down. Just a suggestion! When you shut down your laptop make sure that your shutting down properly at the start button select shut down. If all else fails and this does not work.
You may want to have the power button checked out or the board. Or clean files out and start up programs add-ware or spy-ware may be preventing you from shutting down as well. This is also a common issue that causes very slow shutdowns on any computer system packed up junk having to close out. John
May 11, 2012 | Dell Latitude E5500 Laptop
Slow shutdown HP Pavilion dv7
There are a number of reasons that may causing your HP computer running slow to shut down or start up, but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on to free detect and fix related issues. Regards!
Jan 31, 2012 | HP Pavilion dv7-1132nr Notebook PC
Slow computer shutdown
Tip #1: Cut down of the programs and processes running in the background.--When you start your computer many unnecessary processes are loaded. You can eliminate this by managing your msconfig.
Here is how:
1. Open your Start menu.
2. Click Run
3. In the command screen type "msconfig.exe"
4. In the system configuration utility,click either service or startup tab.
5. Uncheck all programs that your are no longer want to run in the background.
6. Click OK
Tip #2: Defrag your Computer--The faster your computer can find files the quicker it can shutdown. A very slow computer shutdown can be the result of your hard drive trying to search for disorganized and fragmented files that it needs for shutdown . Organize your hard drive by performing a defragmentation.
Here is how:
1. Open the Start Menu
2. Click on My Computer
3. Right Click your C: drive or your hard drive image.
4. Scroll down to the Properties and Click
5. In the Properties Menus, Open the Tools menu.
6. Choose Defragment Now.
7. In the Disk Deframenter menu. Click on Defragment
Tip #3: Clean your Registry- Usually slow computer shutdown often occurs due to a corrupted registry. You should perform a registry clean, use RegInOut to fix this issue instantly.
Dec 18, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Slow shutdown
Try to check-up control panel of your PC, I know your PC configured for automatic windows application update. also try to full scan(present anti-virus software) your PC system maybe same spyware, worms and virus inside on the operating system (OS) and other software desktop.
Please see screen shot picture below.
Oct 18, 2011 | Dell Inspiron 531s Desktop Computer
PC Getting auto shutdown
The most common reason of a PC getting auto shutdown is that the processor may be getting over heated.
Every processor has a TjMax temperature. when the processor reaches that temperature, it starts throttling(slow down) and if it continues to become more hotter then it automatically sends a shutdown signal to the Computer
  • Clean the Heat-sink.
  • Check the fan speed.
  • clean the cabinet.
  • use thermal paste over thee processor.
  • Make sure there is proper ventilation in your cabinet.
Hope this may help you......cheers:)..plz vote
Sep 24, 2010 | ASUS P5PE-VM Motherboard
Runs all the time very slow shutdown
When you shutdown your Windows XP computer, it may take more time to complete the shutdown process. Slow shutdowns are caused by a number of factors. One of the common cause is the Clear Pagefile at Shutdown option enabled.
Some points to improve the shutdown times:
Follow these steps to open registry editor.
  1. Click on start and the click on run
  2. In run dialog box type regedit
  3. Either press enter or click Ok button on the run dialog
Set ClearPageFileAtShutdown value to 0.
Feb 22, 2010 | Computers & Internet
Slow motion, fuzzy scratchy noise, shutdown problems.
the same thing happened to me
this is not a device error but a OS error
to solve this problem
use system restore to restore the system to a date before this error started occurring
this a totally random error that happens due to a code fault
just restore the system to a date where this problem was not there and you will be fine
Sep 29, 2009 | Alienware PC Systems Alienware M17...
I have Dell inspiron 1420, but my laptop starts & shutdown very slowely
hmm that means there are lot of service is running in your computer...try this for starts-
1)open run command
2)type msconfig in run.
3) uncheck all unnecessary program at startup tab then restart system.
now for shutdown pc
try this
1) open run command
2)type regedit
3) search waitforkill registry using ctrl f.
4) increse value of waitforkill like 200 to 20000.
Mar 29, 2009 | IBM ThinkPad T30 2366 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
69 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
