Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Pt-53tw53g Need value for resistor located at r7031, I think it has 222 on it, not sure.
  • 58 Answers
It is a 2.2K ohm resistor, here is the info out of the service manual.
R7031
ERJ6GEYJ222V
RES M 2.2K-J-1/10W
hope this helps.
Posted on Apr 03, 2008
Pt-53tw53g hasflashing light flashes 3 times
Short protection and a 98 percent chance one or more of the 2.2 ohm resistors that protect the two STK-392-110 convergence chips are open.
I will enclose a photo of the chips and directly in front of them are a number of light powder blue resistors----look over the group for ones actually marked 2.2----look to see if any are discolored (somewhat in the middle). A meter can be used to test them instantly---the ones with values marked that are not 2.2 never fail.
If this is found it explains the three blinks---resistor opens and set detects no voltage to one of the two chips and shuts down.
Both chips and any open resistors (usually only one) need to be replaced.
I have my own start to finish instructions with more info based on having done this repair in this set hundreds of times.
A email address will result in getting a copy of them for free--they tell you everything you will need and how to do the repair.
SD TECH
May 23, 2012 | Panasonic Televison & Video
R517 please give value, thank you model # PT-53TW53G D BOARD
R517 is a 10K ohm 1/4 watt carbon resistor part number ERDS2TJ103T
Jul 23, 2011 | Panasonic PT-53TW53 53" Rear Projection...
I have a Panasonic Projection HDTV that i recently adopted. When i took it home I found a blue "bowing" at the bottom of the video. The experts i spoke to said i need to replace the convergence chips and...
The 2 STK convergence ICS are dead,all the resistors too,if it is smoking and glowing.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it again.Find the correct tv make and model.The convergence kit buy from one of these website's will have all the parts to repair it right this time.
Jul 16, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53G coverage wont move the blue color? I DON'T KNOW THE PROBLEM. I JUST REPLACE THE IC'S. pLEASE HELP
Did you check the six 2.2 ohm 2watt resistors? Usually your model will have at least one blown when the ICs fail
Nov 13, 2009 | Panasonic PT-53TW53 53" Rear Projection...
My panasonic TV Model: pt 53tw53g turns off by it self
My Panasonic has exactly the same problem. The repair man just came in and said that the convergence and resistor burned under heat and have to be replaced. Will cost $400.
May 13, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic Pt-53TW53G projection tv
5 Blinks means IC4511 thats located on the DG board which is the small board on the left side in front of the signal board looking in from the rear of the set.
Oct 31, 2008 | Televison & Video
Panasonic 55" PT-53TW53G
Thats a strong possibility that the converegence feed resistors could be open. Also double check the wire connections especially the white bridge connectors that are from one board to the other. Also recheck the IC pins for any sign of bridged pins or inadequate solder.
Jul 08, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic pt 53TW53G
R7015 is 2.2 ohm 2w.......
Rx015 is being researched......
Stk392-110 -120 and -150 upgrade sub to Hitachi kit # X 480293
DO NOT USE GENERIC IC's ! Best is STK394-160E ( two in
kit # above - do not use kit resistors )...................T.
Apr 14, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Parts for panasonic pt-53tw53g
r7011 = 2.2 ohm 2 w...
r7015 = being researched....
Partstore.com ...........................................T.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
