Vcr roller guide arms timout/can't make it to stoppers
I've been trying to trace down a problem with a mitsubishi hs-u776 svhs vcr -roller guides almost make it to stoppers, then timout -had the carriage out and tried hand cycling (without tape) and it would become unturnable at that spot -white greased everything and found when i pushed on double gear loading arm assembly underneath, I could complete cycle, and after a few hand cycles w/grease getting in -seemed fine again -put back together -working again, -for awhile- -this time I notice the left supply arm seems to be the one not making it to stopper and seemed the supply reel was to tight to let arm pull out tape -BUT, i could be wrong, as the first time, i couldnt hand cycle completely without a tape -can anyone point me to likely suspect? should i change the whole double gear loading arm assembly underneath? or is it likely something i've missed? hard to tell if tape is pulling to hard, as how to test that with carriage out and no power to capstan motor, or even if its in how would one do that?
p.s. I have a spare carriage that has all almost new parts except no capstan motor and out of adjustment roller guides, otherwise I'd use it (dont even want to mess w/roller guides ever again) if it comes down to it I will change every last part, as I need this working again -maybe you can suggest an order of parts to change (I also have the service manual, which has been a big help,but it doesnt have any troubleshooting info)
sincerely dennis
  • okeefe58 Apr 01, 2008
    p.s. also, I didnt regrease or check bottom side of cam for obvious reasons-could be another possible problem area -intitially I changed cam motor before I found it was stuck with no results, of course.
  • okeefe58 Jun 27, 2008
    there are no roller guide motors per se -only cam motor (which I already changed) and the servo motor -thanx anyway
Roller guide motors need lubricant?
Posted on Jun 27, 2008
Cable jumps off of roller at end of boom
I've had the same problem with my electric Walker down-riggers, the line guides didnt work well because of the crimp for the cannon ball return pully snags on the guide, the best I came up with is a cannonball snubber similar to ones used with Dipsey-Divers, made heavier for cannonballs, hope this helps
Jun 04, 2012 | Electric Cannon Mag 10 Hs Downrigger
How do I set the clock without the remote?
http://www.ebay.com/itm/HIGH-END-MITSUBISHI-MODEL-HS-U440-VCR-W-REMOTE-NICE-/230751842386?pt=VCRs&hash=item35b9e1b052
Look at link above, you could buy the original remote from e-bay for $25 plus get another vcr. Only two days left so act fast. Universal remotes - try a different one, other than that its going to be difficult. You could also buy another vcr that has its own remote from a thrift shop or craigslist.
Feb 23, 2012 | Mitsubishi HS-U440 VHS VCR
I need a manual to vcr mitsubichi hs 721v
It is my pleasure to guide you.
I am sorry but the news is that this model has no free downloads that I could find. Click the link below to purchase the manual.
QUOTE
MITSUBISHI HS-721V(B) - It's a full owner's manual ( also known as operating manual or user guide), and it's in PDF format. After placing order we'll send You download instructions on Your email.
http://www.manuals-in-pdf.com/index.php?main_page=product_info&products_id=52323
MITSUBISHI HS-721V(B) Owner's Manual $9.99 Shipping costs-download: $0.00
Link to this manual is usually sent within 5 / 6 hours (max. 24 hours).
UNQUOTE
If your set is still under warranty then you could contact the store for a new manual or
CONTACT them at
MEVSA PARTS DEPARTMENT
Service parts including instruction books and remote controls I would try this one
phone: 800.553.7278
fax: 800.825.6655
MEVSA CONSUMER RELATIONS
Product Information, Brochure Requests, and Customer Service Assistance I would try this one
phone: 800.332.2119
MEVSA WARRANTY DEPARTMENT
Mitsubishi Extended Warranty Programs
phone: 800. 888.8245
fax: 949.609.4912
Document Fax-Back System
Mitsubishi Electric Visual Systems America, INC (MEVSA) I would try this one because of the email address
9351 Jeronimo Rd. Irvine, CA 92618
Email:mdeaservice@mdea.com
Good luck and please post back that you are successful, giving thumbs up, or if I can be more helpful.
Jun 13, 2011 | Televison & Video
My player eats the vcr tapes!
It is most likely that the pinch roller will need replacing. Once these become glazed (shiny) the tape slips over them, resulting in 'chewing' as the edges of the tape ride up or down the capstan shaft and into the top or base 'rabbit' of the exit guide nearby. Replace the roller, clean the tape path (capstan, guides, heads, take up arm, etc., *gently of course*) with alcohol solution or methylated spirit - do not use q-tips to clean the drum.
VCR should be OK after that. No further repair should be necessary here, and rubber pinch rollers for VCRs are not expensive to order as a generic part for this model.
Mar 02, 2011 | Sanyo DVW-5000 DVD Player/VCR
Pinch Roller replacement on Mitsubishi Model HSU550
Another roller type thing, attached to baseplate, squeezes the tape against that roller to drive/guide it.
Jan 27, 2010 | Mitsubishi HS-U530 VHS VCR
Cannot load tape. keeps ejecting tape when trying to load.
Remove the top cover from the VCR. If you have children in the house, look for any object lying in the mechanism. If this is clear, insert a tape slowly into the carriage & watch carefully if the cassette tape flap raises up & allows the tape to be lowered down into the mechanism, if not the flap lever at the side of the carriage may be broken. If the tape does lower into position, look to see if the tape is being pulled out by the guide arms, (normally 2 white poles) one of these may be broken. Check the half loading arm is also not obstructing the tape. If any of these parts are broken a new deck mechanism would be required.
Jul 06, 2009 | Mitsubishi HS-U530 VHS VCR
Mitsubishi HS-U61 SVHS
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor. Unplug the unit and take the cover off. Hopefully there will be enough clearance so you can get to the tape. Try to find the motor and belt that is responsible for operating the eject mechanism. The motor will look like a shiny cylinder, about the diameter of a quarter and will have a plastic pulley attched to the shaft. You can rotate the pulley and belt with your fingers and manually eject the tape. If the tape is around the spindles and video head, you will need to manually move the mechansim that retracts the spindles and returns the tape to the cartridge. While you may be successful in getting the tape out, you need to find out what caused the problem in the first place. Putting in another tape will most like become stuck again unless the problem is identified and resolved. Also look for a broken spring or cracked gear (missing teeth) in the eject mechanism. Please let me know if I can be of further assistance Good luck! - Jim
Feb 28, 2008 | Mitsubishi HS-U447 VHS VCR
Language setup for Mitsubishi HS-U510 VCR
try holding down the power button for 8 + seconds upon first starting the vcr. the language option will again be afforded you. see the manual.
Nov 07, 2007 | Mitsubishi HS-U510 VHS VCR
User manual
http://tv.manualsonline.com/manuals/mfg/mitsubishi/mitsubishi_vcr_product_list.html
May 18, 2007 | Mitsubishi HS-U776 VCR
Televison & Video Logo
178 people viewed this question
Top Televison & Video Experts
