Question about LG (CRD-8400CB) CD-ROM Drive
DVD NOT SHOWING
I am having pc with window xp loaded with LG GCE 8526 B - 52 x cd roam. My cd rom is not able to open any dvd file whereas all other functions are normal. When i insert dvd it shows no file ......... even i have reloaded the driver of the cd rom KINDLY help.......... capt.rajesh
  • Rajkumar Bordoloi
    Rajkumar Bordoloi May 11, 2010
    dear Capt.rajesh
    plz clear do u have dvd rom or cd rom.If you are having dvd rom then your dvd rom lense have been dirty or damaged.If it is under waranty then give to the vendor or u can bye a dvd lense cleaner and clean it.If the problem persists then u have to replace the roam.
Yes, go to the cinema to watch movies. ;-)
You are asking a cd-rom drive to read a dvd disk. So it will not work.
Posted on Nov 09, 2008
I have the same problem here. I used to play VCD and DVDs but after restoring my laptop using windows XP CD which I was also runing before the LG CD-ROM CRN8245B could not play the DVD anymore and even to detect it in the drive. I have tried all of the above and it has never work. Aonther solution out there?
Posted on Oct 14, 2008
  • 813 Answers
Hi frined
change ur data cable & power cable & try to ditecing
if not show then do one ting go in a device manager >system devices>pci bus>right click on it & uninstall then ur pc is restarts
& insatll ur all divce drivers correctly
thnx using fixya
Posted on Apr 01, 2008
SOURCE:
Registry corrupted for Gce-8486b CD-RW
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps.
Dec 29, 2012 | Goldstar Gce-8486b Lg Drive 48x/32x/48x...
HL-DT-ST-CD-RW GCE 8483B WON'T BURN cd
What software are you using to burn with? Have you tried other CD's? What are you trying to burn? Is the file/files copyright protected? Will the DCD/CD rom play media? Have you upgraded your OS?
Dec 12, 2012 | Dell Dimension 2400 PC Desktop
I need a driver for a Hitachi LG CD/DVD model #GCE-8483
Windows XP has "built-in" support for reading/writing CDs and for reading DVD disks from _all_ manufacturers.
Access http://www.MajorGeeks.com and search for "Ashampoo burning free version 6". This is _free_ software that makes it easy to burn CD/DVD disks.
Apr 18, 2010 | Computers & Internet
Computer CD-RW
here is your problem - im a expert in cd roms ... put the computer back like you had it
2 download this small file i wrote
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
open the file run it and reboot the computer BINGO it works - this file reset you upper and lower filters in the registry now the cd rom works - let me know
Dec 30, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Cd drive not open when i click on the open button
There is a small hole on the front of the rom somewhere. Using a paperclip insert it into that hole and it will manually eject to see if there is anything jamming the tray. Good luck.
Oct 09, 2009 | LG GCE-8526BL CD-RW Burner
Have a Dell 667Mhz 64mbit ram pc w/windows 98 on
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
Mar 29, 2009 | Samsung SC-148 CD-ROM Drive
Cannot open my computer, laptop model PCGK45.
thats simple ur windows xp is corrupted there is only one thing u can do that is put in the xp dvd and reinstall xp
Dec 17, 2008 | Sony VAIO K45 Notebook
My CD RW drive is not reading any CD
Here is the download page for the firmware update for this drive:
follow these instructions carefully.
8240firm119.exe
(free registration required at Driver Guide)
Firmware v1.19 for the LG GCE-8240B burner. After downloading double-click the file to start the extraction program. Accept the default unzip folder (C \8240firm119) then click the UNZIP button. 2 files will be written to the folder. One is the firmware (the exe file) and the other is a instructions.txt file. Be sure to read/print the instructions before attempting to use the firmware upgrade. Paying particular attention to the section dealing with whether your drive is OEM or LG. This firmware is only for LG drives and will not work on LG OEM drives. Use this file at your own risk. I nor driverguide.com will not assume any responsibility if your drive is damaged.
We are NOT responsible for any mistakes you make or you loosing power during the flash. You should be on a battery backup power supply to ensure you do not loose power.
Regards,
Worldvet
Aug 19, 2008 | LG GCE 8240B CD-RW Burner
Dvd drive not functioning
LG DVD Rom has firmware update files .try to download the appropriate firmware update according to the dvd model
Jul 26, 2008 | Microsoft Windows XP Professional With...
LG CD ROM's
Hi, Why do you want to do this? There may be a different solution possible.
Nov 01, 2007 | LG (GCE-8525BI) (GCE-8526BI) CD-RW Burner
LG (CRD-8400CB) CD-ROM Drive Logo
218 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
