SOURCE: my dryer lg dle 7177 tumbles but does not heat
If you have a gas dryer...
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
SOURCE: My LG DLE 5977 S
Check to see if there is a kink in your vent hose in backj.
Go outside to verify
Clean filter with dishwashing liquid and brush
Run water on filter first to verify it doesn't go through
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
SOURCE: I have a LG Tromm
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For further instructions on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
SOURCE: my dryer DLE 2514W does
disconnect vent hose and run a load of clothes, if they are dry then the vent hose is restricted/clogged. if for some reason it is doing the same then take dryer apart and clean from lint screen back, I am almost certain that it is the vent tube.
SOURCE: Dryer has wet clothes in
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
For video and pictures on how to replace the element go to the following website:
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
