Question about Hotpoint Aquarius WF210 Front Load Washer
Leaking washing machine
My hotpoint aquarius extra is leaking. how do i check to see where the leak is coming form so i can identify which part to repair
  • Hotpoint Master
  • 744 Answers
Hotpoint Aquarius WF210 Front Load Washer Leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Posted on Aug 05, 2013
  • 4 Answers
Check all of the water inputs and drainage on the back
if it is none of those check the stop **** at the back of your washing machine (if you have them)
all of the above you should be able to feel wet patches on the machine or wall
Posted on Apr 03, 2008
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Mar 06, 2017 | Hotpoint Washing Machines
Leak on rinse cycle aotpoint aquarius wmf 540
Check the door seal.could have small rip/ tear around Hinge or door lock position....
Nov 06, 2013 | Hotpoint Washing Machines
Hotpoint aquarius 1000 extra
have you checked belt or brushes in motor
Jan 26, 2012 | Hotpoint Washing Machines
Our washing machine is leaking at the front. What are the most likely causes please, and how can I fix it. It is a Hotpoint Aquarius Extra WMA36 1300 spin. Thank you
It is so common that water leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked from the front then the door gasket can be fault and needs to be replaced
please check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1397/how-to-replace-the-door-seal-on-a-washing-mac.html
If there is leak at the bottom as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
Sep 01, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint aquarius leaking
If this is leaking as its filling check its clean and nothing in it you can also remove drawer, check dispeser hose...good luck
Oct 01, 2009 | Washing Machines
Water leaking from Door and Draw from Hotpoint Aquarius Extra
Had the same problem. I unplugged the machine from the mains. pulled it out from the unit and removed the lid. checked the black rubber hose which leads from the drawer to the drum. it was full of water. i carefully squeezed the pipe and tried to clean it out with warm water to see if it was clogged. still leaking. i then Removed the green paddle on the inside and turned the drum to line up with the black rubber hose that leads from the drawer. I very carefully used a wire coat hanger to put through the gap in the drum left by the paddle. Moved left and right, oh look.... A sock! I manipulated it out of the gap, checked the hose. Water had gone. Put everything back together. No leak. All done in under an hour :-)
Mar 02, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hi i had my washing machine repaired last week as the bearings had gone and it needed a new drum (luckily it is under warranty). Now 6 days later there is water coming from the bottom and the washing...
to find the leak take your lid off + the access panel on the back now turn it on if u still cant find the leak tip it backwards and have another look but it could be a fault theyve done by not sealing the 2 halves of the outer drum if thats the case they should come out to it straight away or get in touch with the trading standards because it has only just been done and it must be something theyve done if it wasnt leaking before
Dec 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Leaks after wash programme ends
Check your inlet hose or hoses if it is hot and cold fill.
Turn off supply to washer and see if it still leaks, if it does then you have water coming from inside m/c somewhere
Nov 23, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WF210 Front Load Washer Logo
200 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
