Whirlpool LER4634J Electric Dryer Logo
Posted on May 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A small sock fell into the dryer lint trap. How can I get it out?\r\nThank you! Jan
Douglas Jensen
Level 3:
  • Master 494 Answers
  • Posted on May 18, 2010
Douglas Jensen
Master
Level 3:
Answers
494
Questions
0
Helped
205587
Points
1354
You can try using a metal hanger to hook it and pull it out, but be sure to unplug the dryer before you try. There is also a small pick-up tool about 2 feet long you can buy at hardware stores for picking up small items in tight places. Good luck fishing!
How do I remove a sock that fell through the lint trap?
How To Fix Dryer Lint Trap Problems (Removing Items That ...
? 5:32
https://www.youtube.com/watch?v=Fcw1aPqGiSI
Feb 4, 2015 - Uploaded by UKaToNeN
Have you ever had something fall down into the lint trap on your dryer? It`s happened to more folks than you ...
how do I get sock out of lint filter shoot of electric dryer ...
www.shopyourway.com > Manage My Life > Questions
I'm sorry to hear that a sock fell into your lint screen chute and I would like to assist you. Be sure to unplug the dryer prior to servicing it! Do not run the dryer until you are able to remove the sock! There are two ways to do this.
2helpful
2answers
Takes extra time to dry the clothes.
You may need to clean out your lint trap. Not just the part that you pull out. I'm talking about the entire tunnel. Even though we empty the lint trap regularly there's a lot that gets left behind and over time can become a fire hazard. Your arms and hands cannot reach everywhere in there. For this you can attach an old sock or rag to a coat hanger that has been opened up. Go down in there a couple of times with it. You'll be surprised at how much stuff comes out. To further help this problem you can also pull dryer out and check that the vent hose in back is clear and free of debris. Cleaning the trap screen (the part you pull out to empty the lint) with HOT water occasionally will also clear residue that has built up from using dryer sheets. Over time that residue will make those tiny screen holes smaller & smaller & smaller. All of this can affect your dryer's performance.
I hope this info was helpful to you. Good luck!
Object fell in lint trap
GO TO A HARDWARE STORE AND ASK FOR A TELESCOPEC MAGNET USE THIS REMOVE CLIPPER FROM TRAP .
Nov 30, 2009 • Dryers
1helpful
Sock fell down lint vent and daughter turned on dryer
Turn off you power to the dryer and then,
You could run a coat hanger straightened out with a hook bent on the end of it into the lint vent at try to hook the sock.
But probably you will have to remove the back to follow the lint vent.
You may try to remove the vent hose and run the straightened coat hanger in there to try and remove the sock.
Hope this helps
1helpful
A sock fell in the vent of my whirlpool dryer
If you mean the lint trap, try this: Unplug the dryer. With a dryer brush (~$10.00 @ Lowe's/similar), bend to approximate the curvature of your cavity and try to retrieve. If this doesn't work, slide/scoot the dryer out and remove the venting duct. Carry outside and dump. If no sock there, look into the dryer exhaust (where the duct connects). Use the brush again to retrieve said sock (and generally clean as you go, as it never hurts). Also look at your vent where your dryer exhaust passes through the wall, clean as you go..... This should get you back up and running.
Regards, --W/D--
3helpful
Lint fell down the lint trap. How do I get it
Luckily, dryers are light. Best thing to do is pull it out until you can remove the back cover. (unplug it first) Then vacuum and clean all the dust and lint you can. This should be a yearly thing at least anyway. Replace the back plug it in and slid it back. I do mine every 6 months or so.
2helpful
Lint fell back into lint trap. how can i get it out? already looked in back.
An appliance store can sell you a brush that is attached to a long wire. It is made specifically for removing lint from dryers. I have seen them at walmart and other places but for sure at an appliance store. Good luck.
2answers
Sock in lint collector slot
Take a hanger Metal one, stick it down there and twist tell you get a good grab on the sock and pull it out. The other way is to open the back up and get in there. The machine will not work at all cause it can not exhaust
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Eager
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
