Question about Sony Playstation 3 (PS3) Console
Dns error (80710102) on my ps3. It works wirelessly fine (but weak signal causes glitches) - but when I use a wired connection it will sometimes work fine for an hour or so and then kick me off the network with this dns error. I then try and reconnect but it says it can find the IP address but not the internet connection (that fails). The dns error appears again. I am in Europe and using a speedtouch wireless modem. I have tried all the fixes on this site - but none make any difference. The last time, I reformatted my PS3 - it worked for an hour or so...then same problem. Help would be very appreciated. Thanks Andy
  • 6 more comments
  • molett May 11, 2008
    i have the same problem
  • size_is_powe Jul 24, 2008
    My internet on my PS3 worked fine for months then stopped working, i did the connection test and it failed on the ip adress, I then changed the last didgit on the ip adress and it succeeds but the internet connetion then fails. Help me please
  • Anonymous Jul 24, 2008
    I do get the following erros message:
    800AD23 ERROR MESSAGE, I'm currenlty conected wireless and have all the ports open as well as assigned my DMZ. Please someone help!!!!!
  • lyttle Sep 23, 2008
    The internet on my ps3 never works. I use wireless and it will work for about 10mins when turn't on but some times wont work for weeks, comes up with this DNS error. The internet connection succeeds but the playstation network rarely does.Some one help me please
  • Anonymous Sep 24, 2008
    i keep getting a error whenever i try to downlaod something for online play on kane and lynch
  • deionfrank Nov 14, 2008
    i am in the united states and my ps3 wont connect to the internedt throught the ethernet cable. but it works ok wireless
  • Anonymous Jan 27, 2009
    when i play most ps3 games, i get sighned out, and then i try and sign in. but it sais DNS error 80710102...it's annoying because i have a belkin wireless router and it was working ok... but i moved it out of the firewall and then it was even better but i never got this problem, just today... PSN( bloodrain9 )
  • minidiver Feb 05, 2009
    im so ******* angry. it was working fine yesterday and now it comes up with the DNS error
Try the dns from opendns.com
Posted on Feb 18, 2009
Please help me iam wired connection to the playstation 3 i have ((dns error)) but i still can make any download please help me quikly ......
engineer.sabah .talal
Posted on Sep 22, 2008
2 Suggested Answers
SOURCE: dns error (80710102) on my ps3
I had the same problem and tried every solution. On the linksys website for my router they said to update the firmware. I did, enabled upnp and everythings good. Just reset you ps3 internet connection, set it to auto and let it do its thing.
Posted on May 22, 2009
How do i solve the DNS error 80710102
It seems like the DNS error is generally caused by problems on your ISP's end of the network, but that doesn't mean you can't have a crack at fixing it yourself.
Under your network connection settings try changing the DNS servers to the following numbers (they're free by the way)
Primary DNS 208.67.222.222
Secondary DNS 208.67.220.220
Also, try disabling media server connection as well. These simple steps should, in 90% of cases, fix the problem.
I've written a more in-depth guide to the causes of, and solutions to the DNS error- check it out here http://searchwarp.com/swa641197-Ps3-Dns-Error-80710102-Troubleshooting.htm
Read more: What is a dns error (80710102) ' Answerbag http://www.answerbag.co.uk/q_view/559164#ixzz15vEULfUP
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
Dns error(80710102)
Hi
Error 80710102: Cannot connect to the internet.
This may be caused by inputting the incorrect information when setting up your internet connection. Alternatively or it may be down to internet lag due to congestion with your provider or a weak wireless connection.
It is advisable to go through and recheck your internet settings. See links on how to do this.
For troubleshooting a wireless connection see
http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=280&p_sid=RV8IM8Nj
For troubleshooting a wired connection see
http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=285&p_sid=RV8IM8Nj
Thanks for using FixYa. A helpful rating to this answer would be appreciated.
Nov 16, 2009 | Sony Playstation 3 (PS3) Console
DNS ERROR 80710102
have you tried opening some ports on your router for the ps3?
Jun 09, 2009 | Sony Playstation 3 (PS3) Console
Can't connect to the internet wireless, I get a DNS error (80710102)
Try disabling the "WEP" key on you router. I've read the solutions from other contributers and tech's and this solution seemed to really work.
May 31, 2009 | Sony Playstation 3 (PS3) Console
DNS ERROR 80710102 DIFFRENT PROBLEM
I have had this same problem do you have verizion if you do then simply change it to myfairpoint.net do system update and change it there then if it still does not work try adding a wired connection hope this helps :-{D
May 25, 2009 | Sony Playstation 3 (PS3) Console
Dns error (80710102) on my ps3. It works wirelessly fine (but weak signal causes glitches) - but when I use a wired connection it will sometimes work fine for an hour or so and then kick me off the network...
Apr 11, 2009 | Sony Playstation 3 (PS3) Console
Dns error 80710102
try mving your ps3 around into verous places around the room and try to find an internet connecion. you can go to settings, network settings, then settings and connection status list and it will show you how much internet you have.
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wireless internet connection wont work!
Ok, sometimes consoles dont like to be on the same network as other devices so it causes Ip and DNS conflicts. You just need to play around with the settings till it works.
Jun 17, 2008 | Sony Playstation 3 (PS3) Console
PS3 Error Code 80710102
The 80710102 problem is caused by a DNS error, which basically means that your PS3 is trying to navigate the Internet without knowing where it needs to go.
If you follow the link below I have written an in-depth (and free) article about how to fix PS3 DNS errors and get rid of the 80710102 code on your console.
Mar 30, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
867 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
