Question about Nokia N70 Cellular Phone
My n70's back camera is not working properly.it take several minutes to be activated.if it is activated.itis stopped with in one second.my bluetooth is not also working properly.plese help me?
  • 2 more comments
  • jacksandra Apr 02, 2008
    my N 70 phone is hanging freqently
  • mo3396 Jul 07, 2008
    My N70 back camera hasnot working properly . I recieved a solution like "make good mobile like rs 1500only mp3 ".but idonot understand it.What does rs 1500only mp3.please help me
  • bharthiraja Aug 08, 2008
    After opening the camera automatically its getting closed.
  • kewalgirase Mar 01, 2009
    N70 BLUTOTH AND CAMERA NOT WORKING
  • 16 Answers
Please check your back shutter it connected with a camera switch.
Remove the back of your phone & then set it again.
When you transfer data through Bluetooth, your phone should be directly in range of 10-15 metre
& your phone must be in "Shown to all" to work properly.
Posted on Jul 29, 2008
While opening the camara window unexpected error occured power off the device and restart
Posted on Sep 13, 2010
Change camera ic it works
Posted on Jul 16, 2010
Make a good mobile like rs 1500only mp3
Posted on Apr 01, 2008
I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
Oct 31, 2012 | Audio Players & Recorders
I have the same problem. An N70 with the err message. If the rewind buttons are pressed (without any film in the camera) the camera tries to rewind but will only stop if the back is opened. I tried...
The Err message alone indicates that a malfunction has been detected, and the manual recommends to fire the shutter and check for the message to clear. If it does not, to contact a Nikon Service Rep.
If it is Err + E, the film did not advance properly and needs to be reloaded.
May 03, 2011 | Nikon N70 35mm SLR Camera
N70 not switching on
take the battery out, leave for 2 minutes then put it back in and see how that goes
May 31, 2009 | Nokia N70 Cellular Phone
The back of my nokia n70 is not working properly...please help!
because it is not the factory settings which cause the problem,, it is the software itself, the only solution of that is to reformat
May 26, 2009 | Nokia N70 Cellular Phone
Cannot pair Nokia N70 to Jabra BT150 bluetooth headset
turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
Dec 07, 2008 | Jabra BT150 Wireless Headset
Bluetooth operation problem
you need to go technician then ask them to reformat your n70 phone,so that it will work well.
Nov 22, 2008 | Nokia N70 Cellular Phone
Unlock nokia N70
Network code 23415000 Vodafone; United Kingdom.
IMEI 358637014464223
Phone model: Nokia N70
To enter the code to the phone (switch on without SIM card).
Input the Code in the phone as follows:
Your code's are:
#pw+089553613737057+1#
#pw+447937471501734+2#
#pw+949472576726771+3#
#pw+004003133262404+4#
#pw+449977373741273+5#
#pw+829031751772532+6#
#pw+878801503630103+7#
First code in the end of the string must be added + 1#
Code number 7 in the end of the string must be added + 7#
If you have proper software and You know on which lock, phone
is closed just simply enter proper CODE.
If YOU DONT KNOW – which lock is closed do the following:
1. Enter the first code, if it’s the wrong code – WAIT 30 seconds!!! And then:
2. Enter the code number seven this will open all locks.
How to get ‘p’ ‘w’ ‘+’ signs?
Press
* several times on keyboard of phone.
Now a message should appear something like “Sim restriction off”. That means your phone is now unlocked.
!!Warning!!
If the codes don’t work after entering 5 codes You will lock the ‘CODE UNLOCK FUNCTION’ and it will be possible to unlock the phone only by using a cable/device.
May 21, 2008 | Nokia N70 Cellular Phone
Please help me!!!!!!!!!!!! Nokia N70
it seems like u have a soft problem so u should better take that phone to a nokia asistance...
Feb 07, 2008 | Nokia N70 Cellular Phone
CHINA MOBILE N92
Hi
You can reformat your unit.. just follow this instructions. just off the fone then, press together the key no. 3 Astiris and phone in.. press in sustained position then turn on the power switch then you can see your fone is starting to refurmat...
Jan 07, 2008 | Nokia N70 Cellular Phone
Garmin NUVI 660 BlueTooth
I had the same problem, and this is how I fixed it. Now it's working fine.
Thank you for contacting Garmin International,
If you are currently running the most current version of bluetooth software, and you are still seeing issues where your compatible phone is still not connecting properly, please try the below procedure, which will reinstall the version of bluetooth you have downloaded in case there was any corruption during the transfer or installation of the bluetooth version.
1. Power the unit on
2. Touch View Map
3. Touch the ETA/Speed button in the bottom left hand corner.
4. press and hold your finger over the speedometer for 10-15 seconds until a new screen appears.
5. Touch next at the bottom of the screen until the top blue banner reads Bluetooth Status.
6. Touch UPDT P, then Touch yes.
7. At this point the unit should go to a page that says Updating Bluetooth Firmware, allow this to finish, once finished, press quit, then press and hold the back button. At this point, go back through and try to connect your Bluetooth device again.
Dec 29, 2007 | Garmin Nuvi 660 GPS Receiver
Nokia N70 Cellular Phone Logo
756 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
