Pioneer VSX-D702s receiver - no sound - need help/circuit plan
Hi there
my old Pioneer D702s receiver is out of order.
How it used to be:
I was used to hear a relais clicking after I turned on the unit. Once the relais closed/opened the receiver would work just fine. It used to take only a second or two until the receiver was ready.
How the problem started:
I noticed that my receiver would need more and more time to get ready. Sometimes it would take minutes until I heard a relais clicking.
How it got worse:
That relais click problem got worse. It would need more and more time. Sometimes the problem would even occur when I switched to another input source. I would have to wait for that relais again.
Today:
Receiver turns on. I can select inputs and whatever but theres no sound.
I know that the modell is very old but I like it :) Could someone provide me with a circuit plan or service manual? Anyone having/had trouble with same modell?
Thanks
  • silyb0y Apr 01, 2008
    I forgot to mention:
    Ive already checked for blown fuses, short circuits and bad solder joints. I really need a service manual or advice from somebody whod been dealing with this problem before.
    Thx
  • 4,234 Answers
The unit is in what is called "protect" mode. A problem was detected in the final output stage and that stage is turned off. The most common reason for this is failed output transistors. This is a simple repair for any repair shop and will cost about $10-$15 for parts plus the local labor charge. Expect that the output transistors plus a few supporting parts to be replaced. Most of the time, only one channel is badm, but due to the design of the protection circuit, both channels are turned off.
Dan
Posted on Apr 01, 2008
SOURCE:
I bought a used Pioneer VSX 50 receiver and it did not come with the remote My old remote is not pairing with it. How do I get them to work together?
Hi Pamela,
if the old remote is not for the same make and is not one of those multi remotes that can now be bought then it will not work with the pioneer VSX or if it is from another Pioneer VSX then it may need to have the code re entered by Pioneer.
I would suggest to go to a shop that sels equipment of the same kind and ask for their advice and also whether they do multi controllers that would work, a shop such as Maplin (if you have a Maplin store where you live as they can be very helpful with such problems).
GOOD LUCK.
Feb 06, 2015 | Pioneer Elite Vsx 50 Av network receiver
PIONEER VSX-27TX RECIEVER
Hi!
you can locate the R9371 & R9374 beside or the same circuit of the IC 9374 Very near not far to IC 9374.
Nov 22, 2007 | Pioneer VSX-27TX Receiver
Pioneer vsx-521-k power goes on then off
Sounds like a short in the amp that will need to be repaired before the unit will stay powered on.
Feb 25, 2013 | Pioneer VSX-455 Receiver
I have a Pioneer VSX-515-K A/V Reciever. When I plug it in the power relay clicks continuously. I don't have the schematic to troubleshoot the circuit. I just want to make sure it is the relay that's bad...
A bad relay won't pick and release itself. You need to find the cause.
Here's the Service manual.
http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-515_RRV3092.pdf
Page 66and 67 have a timing sequences for power up and down.
Pages 72 and 73 describe a possible loops - DC abnormality and Fan Stopped.
Mar 16, 2011 | Pioneer VSX-515 Receiver
I need the manual for a pioneer vsx-d702s a/v stereo receiver, can anyone help me?
this should help
http://www.stereomanuals.com/man/rep/pioneer/pioneer2-u-vz.htm
Jan 02, 2011 | Audio Players & Recorders
Pioneer VSX-01 TXH receiver turns off
Sounds like the speaker circuit is overloading or the receiver is overheating.
Check to make sure all speakers are in phase. Pos to Pos. Neg to Neg.
Make sure receiver has plenty of cooling room.
Hope this helps.
Apr 16, 2010 | Pioneer Elite® VSX-01TXH 7.1 Channels...
Receiver - manual service
Still need to solucção pioneer VSX-605s and-505s not VSX. I want to thank the provision of his plan. I am more in search of the manual services of receiver VSX-605s ....
Oct 14, 2008 | Pioneer VSX-505S Receiver
Pioneer vsx d512
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
Aug 03, 2007 | Pioneer VSX-D511 Receiver
The Sound is Gone.
Hi....
The circuits that routes all the audio signals thru the amp has either died OR the power supply that runs that circuit has died.
Estimate to fix : $75-125
Apr 22, 2007 | Pioneer VSX-D711 Receiver
Pioneer VSX-D498
Sounds like the on board computer (micro-processor) is waiting for a process to happen and when it does not happen then the unit times out and shuts off. Could be a mechanical or electrical process. Good luck.
Mar 23, 2007 | Pioneer VSX-D498 Receiver
1,361 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
