I have an avr635, and recently it's been blacking out. in such that when the volume is slightly higher than usual it will shut itself off, into power save mode that is. I have 2 old sansui sp450 speakers hooked up, still in great shape, and can handle my needs well. any ideas? i've heard possibly, there is a cooling fan inside the 635, and that this could be malfunctioning, if this is the case, how would i know if it's not working? look forward to any help you can provide. Doug. doug.clapp@rogers.com
    Sergeant:
  • 247 Answers
Open up the case and you'll see if the fan is working. Or you may be able to tell even with the case on. However, AVR's usually do not use fans.
Here are a few tests to see what may be going on: First check to see if the speaker wires are frayed or shorted. Perhaps they are touching near the speakers or AVR. Replace the wires to be sure. Then test the AVR by using a different set of speakers, preferably ones that are higher efficiency. That means they need less power to drive them. You can tell because high-efficiency speakers will not be sealed tightly and have ports or air holes in the case. Your sansui's are probably low efficiency ones (which sond better,) but need more power to drive them.
If the wires are not the problem and the higher-efficiency speakers do not help, try temporarily using a computer type fan on top or on back of the AVR to see if it works with the fan.
If it is not overheating, you probably have a bad output transistor or faulty power supply on the AVR.
Hope this helps :)
Posted on Apr 01, 2008
Sony HCD-GT222 Hi-Fi CD and cassette deck with tuner, suddenly started to shut itself down at volumes higher than 50%, after three years of flawless operation.
It's thermal; protection is happening probably due to bad ventilation. Fuzz and dust can block air vents.These need to be vacuumed out now and then.
Jan 22, 2014 | Audio Players & Recorders
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Home Theater Receiver turn itself off at higher volumes
Could be that the speaker are being over-driven. The harder a speaker is pushed, the lower the resistance becomes, and the receiver could be sensing it as being a short and shutting itself down to protect the amp.
Jul 10, 2013 | Audio Players & Recorders
Mitsubishi big screet HDTV after being on for a minute, the scree pops and goes black with some red lines, then the volume turns all the way up by itself.
Do the self check----if set has been unplugged plug it in and turn on for it to fail----when it shuts off ON THE FRONT OF THE SET press and hold both the menu and input (device) buttons at same time for at least 5 seconds and release both.
Power light will blink a two digit error code like, 1 blink, 2 blinks and pause and repeat it for a total of 5 times.
What if any error code do you find?
Jun 16, 2012 | Mitsubishi WS-55513 55" Rear Projection...
When warm, or playing loud it shuts down
Hi...
If you can solder and not electrocute yourself, there are some can shaped capacitors(condensers) in the power supply . They'll read something like 4700uF 50V
or 6800uf . Usually blue or black color. If theyre swollen or the plastic wrap around them is shrunk away, theyre bad
replace with same value but the voltage can be higher
Mar 18, 2010 | Technics Audio Players & Recorders
TV turns off by itself or volume goes out usually within the first 15 minutes. The volume will go off and then I'll try to change stations and tv is black, I have to turn off, wait till the VIZIO light...
your Audio output chip has gone south and shorts out after warm up The unit will shut off to protect itself you need a tech to replace it try Pinicle Service solutions in Haverhill ma
Nov 02, 2009 | Vizio GV46L 46 in. LCD Television
Sound problem
On you screen there are button, which you can change settings on your screen itself , go to the volume control, and just set your volume on your screen higher, note: not on your pc, but on your screen itself.. enjoy the sound
May 25, 2009 | Computers & Internet
Head Unit of boat stereo cutting out at higher volume
check your ground wire ..
then check battery has enough charge..
usually fault is in where your stereo is connected to your ground source.. good luck ,if no luck try your checking your speaker wires for a short..
May 14, 2009 | Kenwood Car Audio & Video
Onkyo 705 receiver shuts off at higher volumes
I had this same problem and it turned out to be a twisted kink in the speaker wire. Run a sound check to each speaker separately (from your receiver menu) and turn each one up until the receiver shuts off. Check the wire to the speaker that caused it to shut off and make sure the +- ends are not touching each other at either end, and that there are no twists or kinks along the way.
Nov 04, 2007 | Audio Players & Recorders
62 people viewed this question
 Grubhead
Grubhead
