Waste ink absorber on canon iP 1600
Hi, I keep getting an error message that the waste ink absorber on my canon iP 1600 is full. Iknow that by hitting resume fixes the problem temporarily, how can i clean the ink absorber so that the message stops for good? I get the waste ink absorber full error on my canon pixma ip1000 printer...What can I do??
  • 2 more comments
  • summoner Apr 03, 2008
    somebody told me I only have to reset the counter...I didn't have to open it or something...Txs for the advice though...
  • Anonymous Aug 24, 2008
    hi, printer show error message that the waste ink absorber on my canon iP 1000 is full.
  • putariff Sep 18, 2008
    cannot print
  • kayin_1993
    kayin_1993 Jan 20, 2012
    Cleaning Waste Ink Absorber Cannon IP1600 without tearing the whole printer apart(theres no need to, really.)
    Materials needed:
    Cotton buds, tissue paper, warm water,long tweezers/ Chopsticks (its quite useful if you know how o use it),toothpick/something with a fine end, torch
    1)Unplug the printer. Put it on you desk so its easier to work with.
    2)Lift up the cover of the printer. There should be a whitish kind of tape-like ribbon attached to the ink cartridges. The ink cartridges should be the the very right end of the interior of the printer.
    3)Gently pull the ribbon the is attached to the cartridges so as to expose the waste ink absorbers that nest directly underneath the original position of the cartridges. For your convenience you can just pull the cartridges to the very end so you have a bigger working area. The waste ink absorbers are really tiny,hard and flat pieces of material that are around 1+ to 2cm long in breath and length.
    4)Using a torch, locate the waste ink absorbers (2). They should be held by two small black flaps each. If you are really not sure just use a tissue and feel around. The area where you get a exceptionally much ink stains should be at/pretty near the absorbers. Using tweezers/chopsticks, remove the absorbers carefully(don't lose it). You might wanna clean up the interior abit using cotton buds..
    5) Press each absorber gently in between layers of tissues to get some ink out first. After that just rinse it with warm water. (I just used warm water, but if you have cleaning agents you can go ahead and use them) Dry it in between layers of tissues and air it abit for further drying.
    6) After it is dried you can put them back to their original positions. Keep them in place with the flaps on the sides. The flaps can be easily put in place with the help of toothpick/fine end objects. If you cannot reach the flaps just use the tweezers to help you with it.
    7) Next up, at the base of the interior of the printer you can feel something soft and spongy. It looks like a long grey piece of delicate sponge. Clean that too if it is dirty. Replace it after cleaning and drying. Be careful not to tear it and remember to put it back securely, by using cotton buds to tuck it into place, if not it might interfere with printing process or come lose while printing.
    8) Reset your waste ink counter (there are walk-throughs online) --->http://tricks-collections.com
    9) If not reset your printer. I did.
    [ Step 1 : Manual Temporary
    1. Unplug power and USB.
    2. Open cover and hold power button.
    3. Connect the printer cable.
    4. Close door, then release power button. ] ---credits:http://printertools.blogspot.com/2007/12...
    Kay thats all folks! I had a REALLY TOUGH time trying to figure out all these myself, GAWD. Hope my experience will be helpful to you though! :)
    Genius:
  • 2,785 Answers
U have to clean it mannualy by opening it. if u r not expert give the printer to qualified proffesional
Posted on Apr 01, 2008
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
My printer canon ip 198 shows error e5..what should i do?
Hi there
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E16 - Ink remaining is unknown
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Feb 23, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Hi, I have a Canon PIXMA iP 1600 printer. Recently, I started to get a message that says: The waste ink absorber is almost full. Press the printer's RESUME button to restart ...
I have a Cannon PIXMA ip 1600 printer. Recently, I am getting a message that says: The waste ink absorver is almost full. Press the printer's resume button to restart printing. What is this ? How to solve this problem ?
Jun 15, 2009 | Office Equipment & Supplies
Ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Apr 08, 2009 | Canon PIXMA iP1600 Printer
Error message
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Jun 30, 2008 | Canon PIXMA iP1600 Printer
Try reading THIS .
Hope that fixed ya...
Geno
Apr 04, 2008 | Office Equipment & Supplies
For Canon ip1000 and ip1600, maybe others
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
Or
http://www.servicemanuals.ru/download/canon/ip1600.htm
Aug 13, 2007 | Canon PIXMA iP1600 Printer
1,133 people viewed this question
jasbo
jasbo
