Hoover top loader washes &
Hoover top loader washes & drains but wont spin!
    Genius:
  • 1,198 Answers
Check the lid safety switch.
Posted on Apr 03, 2008
SOURCE:
I have a Hoover Top Loader HNT2135. The problem is that it will not spin. Makes a noise as though it is going to spin but doesn't manage to.
Hi.
If it does make noise and does not spin it is usually the drain pump clogged. Disconnect power, reach the drain pump and check for blockage in there . If that is not the problem check in order drain hose at the back, lid switch, pressure switch, and finally pump and motor from underneath the washer. The switches and motors can be tested using a multimeter.
Here a page about drain/spin problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 13, 2011 | Hoover Nextra HNT 2135 Top Load Washer
Hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
Jan 30, 2008 | Hoover Nextra HNF 3167 Top Load Washer
Wont drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 14, 2011 | Hoover Nextra HNF 3157 Front Load Washer
I have a Hoover washing machine, its a front loader, I don't have the exact model in front me at the moment. I recently moved house, and yesterday after re-plumbing my washing machine, I put the washing...
If water remains in the drum after the drain cycle, the unit will not go into the spin cycle. There may be a couple of reasons for your problem.
Make sure the drain hose is raised above the machine hose outlet to create a siphon effect. The drain hose needs to have a loop in it to work correctly. You can tie a string around the hose and hook it on the water valve creating a loop in the hose. Raise the loop of the drain hose so the top of the loop height is at the center of the washer drum.
Apr 06, 2010 | Hoover AI130 Front Load Washer
Hoover washing machine wont spin
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Nov 01, 2009 | Hoover UltraCare HC6 160E Front Load...
Top loader 600MB fills water but wont wash or spin.Water fills to right level and timer turns o.k.
Check the lid switch for proper operation. If the switch is bad or not being actuated by the lowered lid, it will block operation of the machine.
Oct 20, 2009 | Hoover HTC243 Top Load Washer
Water wont go out of my top loader
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure nothing is clogging the pump, like the occasional stray piece of clothing, and check the pump impeller. Make sure there are no broken or missing blades and that the impeller will spin freely. If any blades are broken/missing or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 14, 2009 | Hoover HTC243 Top Load Washer
Hoover 750lb
if its a top loader check for timer/timer module fault.front loader check carbon brushes in motor
Feb 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Hoover 2305 washine machine wont spin
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
