Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Indesit 18 in. D41 slim line dishwasher
Hiya i know that the problem is a leak but i cant find where it is coming from !
When i turn the machine on to do any cycle it lets a little water in then it starts leaking from the bottom of the machine it seems to stop taking any more water in and makes a clicking type sound untill i turn it off. I have checked every where but cant see any obvious sign of where it could be coming from,
  • 4 Answers
Pull the unit out and tip it carefully to one side. (put some rag down first to mop up the water) then stand the unit back up.
Make sure you can see the back of the unit. put some tissue paper behind the plastic pipe that runs up the back centre of the machine. Turn the unit on and put into cycle. after a few minutes carefully remove the paper if its wet (even a little) the chances are the star shaped lock nut inside is loose or the pipe is damaged. A replacement is readily available and should cost less than a tenner to buy. just make sure you order a new seal as well and get a 20-25mm jubilee clip to replace the one installed.
Posted on Apr 24, 2008
Dishwasher
I left mine disconnected and it leaked did you fix yours?
Aug 25, 2013 | Indesit 18 in. D41 Slim-Line Free-standing...
My indesit IDL40 slimline dishwasher keeps leaking?
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Sep 25, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
D41 Model. Switch on, small beep, pump starts, small beep, first green light flashes, no water enters the machine
Check that the water is turned on. There may be a fitting with a screw driver slot in it. This slot shows the direct of the hole that lets the water through and therefore it should be lined up with the pipe direction.
If it isn't turn it through 90 degrees.
Feb 18, 2010 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit 18" d41 dishwasher leaking from bottom of door area
Leaking Dishwasher
heatman101
,.gf.lo
Jan 23, 2010 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D41 dishwasher, switch it on to program,
if applaince does not start draining then there is a possible fault with the door locking assembly,and the appliance thinks the door is open and this will not allow the appliance to start
Jun 28, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit idl 40 2&3 lights flash
The problem is lack of water. Check that the water is turned on at the stop **** and make sure that the hose hasn't been traped if the dishwasher has been pulled out from it resess as happened to mine.
Jan 21, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher indesit DI62
green light 2 flashing sounds like machines doing something switched of at mains & back on to same flashing green light
Mar 01, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit dishwasher.
It sounds like the anti flood switch is activated, lean the dishwasher back at a 45 degree angle. If water comes out the back you have a leak. Stand it up and try it try dishwasher, if it works this comfirms leak, you will need to find where it is coming from.
Dec 03, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit d41 dishwasher
try testing the door interlock, actually this is only a micro switch inside the door behind the plastic front panel, there could also be the possibility there is a broken wire behind the door skin just above the hinge part, take care when working on appliances do not force parts to remove them and always unplug at the mains hope i have helped, if so please rate me well
Sep 26, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
82 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
