Disk checking problem???
Good day whitetiger93,,this is bamboo40,im using windows xp and every time i opened my laptop,the disk check is schedule will appear even if i did not scheduled it.and it will cancel it on its own..i cannot perform defragment also coz of that disk checking schedule..hope you can help me...appreciate it too much..
  • tracyls79 May 28, 2008
    I too have the Gateway Model MX6920. It said I had a corrupt file and then it ran a scan all by itself and said I needed to defrag the system. I told it to go ahead and defrag and it replied with an error message stating that chkdsk was scheduled to run on the drive and I needed to run chkdsk. So, I did that. It said system is NTFS and cannot run chkdsk but would run in read only mode. It ran and deleted all kinds of corrupt files (which shouldn't be there as I don't do anything to corrupt the files and haven't changed anything I've done since I purchased the computer). It said it was scheduling chkdsk to run on startup. Well I rebooted the computer and it didn't run anything. So I shut it down, waited a few minutes, then restarted it again, still, nothing. I tried defrag again. Same message. Then I researched the command lines to see if I could cancel the scheduled chkdsk. I did what it said to no avail. It still didn't fix anything, still refuses to defrag, won't run chkdsk, scan disk, or anything even remotely close to it. Anti-virus comes up clean other than saying I need to defrag the drive. Spyware is clean. Everything else checks out fine. Now I've started getting new corrupt file error notifications warning me to run chkdsk. It's not doing any good as it doesn't do anything but delete a bunch of stuff and cause programs not to work right anymore. I tried reinstalling some of them and the problem is not fixed. I read somewhere that this is a known problem with the gateway MX6920 but I can't find it now and it's driving me insane! I have to work from this computer and now my work program is corrupt and cannot be fixed. We've attempted everything and still no luck.
  • Rajkumar Bordoloi
    Rajkumar Bordoloi May 11, 2010
    what is your file system fat or ntfs
    Genius:
  • 1,913 Answers
I think your harddisk got bad sectors.
use scandisk .
or remove the bad sectors with bootable cd.
Posted on Apr 03, 2008
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
Disk fragment
You need to run chkdsk...
How to run Chkdsk
Notes
Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
Chkdsk might not accurately report information in read-only mode.
How to run Chkdsk at the command prompt
Click Start, and then click Run.
In Open, type cmd, and then press ENTER.
Use one of the following procedures:
To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
Note If one or more of the files on the hard disk are open, you will receive the following message:
Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
How to run Chkdsk from My Computer or from Windows Explorer
Double-click My Computer, and then right-click the hard disk that you want to check.
Click Properties, and then click Tools.
Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
To run Chkdsk in read-only mode, click Start.
To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer?
Click Yes to schedule the disk check, and then restart your computer to start the disk check.
The following table lists the exit codes that Chkdsk reports after it has finished:
Exit code Description
0 No errors were found.
1 Errors were found and fixed.
2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified.
3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
Aug 19, 2012 | Computers & Internet
What is the solution to "Exception EOleSysError module at 00058E75."
Try this:
Run a CheckDisk:
(Windows XP)
  1. Click Start, and then click Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
      Windows Vista & Windows 7
      You can launch CHKDSK using two methods (the former being the easiest):
      Graphical Interface:
      Open the Computer option from the start menu, which will display all of the drives available to scan on your PC:
      Then, right click on the drive you wish to scan for errors and select Properties:
      Now click the Tools menu, then Check Now under the error-checking section:
      You have several options within the check disk tool. It is always recommended you leave the "automatically fix file system errors" box checked, as this repairs and problems found. If you want to perform a deeper scan, tick "scan for and attempt recovery of bad sectors". This second option takes longer, but is worth doing if you suspect a drive problem. Once you are configured, click Start:
      If you try to check a disk that is currently in use, you will receive a message asking if you wish to schedule a scan. Accepting this will perform the scan next time you restart your PC:
      Good Luck!
Aug 17, 2012 | Computers & Internet
My computer crashes a lot. How do I fix?
You may run or perform Disk Error Checking(This is for Windows XP SP3):
* Chkdsk (Chkdsk.exe) is a command-line tool that checks volumes for problems. The tool then tries to repair any that it finds. For example, Chkdsk can repair problems related to bad sectors, lost clusters, cross-linked files, and directory errors.
** How to run CHKDSK at the command prompt:
  • Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
  • Once done with chkdsk r, run FIXBOOT and press ENTER.
  • Sep 08, 2011 | Dell Dimension 4600 PC Desktop
    Hello my acer laptop is giving a message disk error hit alt ctr del for start up i do that but the screen stays black with a with small white blink - in the left hand upper corner
    How to run Chkdsk loadTOCNode(2, 'moreinformation'); Notes
    • Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
    • Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
    • Chkdsk might not accurately report information in read-only mode.
    How to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
    How to run Chkdsk from My Computer or from Windows Explorer loadTOCNode(3, 'moreinformation');
    1. Double-click My Computer, and then right-click the hard disk that you want to check.
    2. Click Properties, and then click Tools.
    3. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
    4. Use one of the following procedures:
      • To run Chkdsk in read-only mode, click Start.
      • To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
      • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
      Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer?Click Yes to schedule the disk check, and then restart your computer to start the disk check.
    Collapse this tableExpand this table Exit code Description 0 No errors were found. 1 Errors were found and fixed. 2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified. 3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
    courtesy of Microsoft.com
    Oct 14, 2010 | Acer Aspire 5315 Notebook
    Bsod
    if your having a blue screen error. Try to load your operating system CD and perform a CHK DSK by repeatedly press F8 on the pc, then boot to safe mode with command prompt..
    Then perform this steps manually:
    Manual steps to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
    1. Click Start, and then Run.
    Hope this helps...
    May 08, 2010 | Microsoft Windows XP Professional With...
    Can read the drive, directory corrupted
    just run chkdsk command to recover your directory structure,
    Hope this helps. Please rate my response.
    Thanks.
    Have a good day
    Apr 22, 2010 | Hitachi hts548080m9at00 80 GB Hard Drive
    Can not use defragmenter on computer. Windows XP system, when I try to defrag I get a message disk defrag has detected that chkdsk is scheduled to run on the volumn:(c:) Please run chkdsk/f. When I try...
    check additonal instructions on:
    http://support.microsoft.com/kb/315265
    This will help you to solve the problem
    Aug 30, 2009 | Computers & Internet
    HI.. i am using windows Xp pro ... i had found a blue screen saying like Checking Disk Files before logging into my user account...i used to skip disk checking but when i had contiinued with disk checking...
    Checking disk files is an important part of the post start up, it normally only does it when scheduled, this check will find any problems and fix them, the best thing to do is just buy a new HDD
    Dec 27, 2008 | Computers & Internet
    I really need to know what OS you are using. XP/Vista???
    Also, could you be a little clearer on what software. I don't want to give you the wrong information. That would only make it worse.
    Get back to me. Thanks.
    Mar 30, 2008 | Computers & Internet
    Computers & Internet Logo
    David Payne
    David Payne
