Video Game Consoles & Games Logo
Posted on May 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ok so i just found my memoy stick under the bed then i put it in my psp the orange light of the memory was blinking . Then i was starting my favorite game rockband unplugged then it said no memory stick then i looked at the memory light and it was blinking but in my game said there is no memory stick. HELP! :(
Anonymous
Level 2:
Sergeant:
  • Expert 230 Answers
  • Posted on Jul 04, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
230
Questions
0
Helped
76331
Points
604
Either a data or file corruption or the memry stick was damaged. Try to reformat the memory stick and if it won't work you'll need to buy a new one.
Hi My PSP's orange ligth won't turn off just always lightning when turn on my psp it's lightning with green light
Hi khangal74,
If you dont have issues playing your usual psp games, you dont have to worry about the orange light. That is normal. It means that your PSP is saving the data to your memory stick. Also make sure that your WLan switch is turned off ( that also causes a blinking orange light ). However, if you are experiencing a flickering orange light and your screen remains black ( and you cannot play any games), it means that your PSP is having issues reading you memory card.
Do these:
Remove the memory card and turn your PSP on without the memory card (it should turn on with no problems) Now, slowly re-insert your Memory stick. (You may need to do this several times until your PSP recognizes your memory card) If this still does not work, your Memory stick is busted or may be infected with a virus and therefore needs to be replaced.
Wishing you with positive results. All the best to you.
How to chicken?
Hello there Sir/Madam! My name is Alex and I work under FixYa.com expert team surveillance.
Firstly make sure your PSP-3000 or TA88v3 PSP-2000 has PSP Firmware 5.03 installed. Check in your PSP XMB go to Settings/ System Settings / System infomation. If you don't have PSP 5.03 installed download it here. Create a folder called UPDATE in PSP/GAME on your memory stick and place the eboot from the archive into the folder. Run the 5.03 Firmware update from GAME / Memory stick and you will have 5.03. The firmware required to run ChickHEN.
Now download the ChickHEN R2 release from here. Open the CHickHEN R2 archive and place the folder inside Slim with gif images into your PSP memory stick location like so PSP/PHOTO (later it will be PSP/PHOTO/ChickHEN). Now place the h.bin into the root of your memory stick pro duo. Where the folders PSP, MUSIC etc are located.
Ok next step place the memory stick into the PSP. We have found this step helps ChickHEN boot with less attempts, go your PSP XMB, to settings and Restore Default Settings. Your PSP will reset, now go back into settings and turn off UMD Auto-Start and UMD Cache. We found ChickHEN loads in 2-3 goes after doing this.
Now go into Photo / Memory Stick and ChickHEN. And wait, you will see five egg giff images, these will start to load thumbnails. Your PSP may freeze and reset. Just keep retrying and ChickHEN R2 will load up....But if you see flashing colors, your PSP will reboot into ChickHEN your homebrew ready!
With ChickHEN R2 loaded now starts the fun part. (P.S You can put your PSP into standby now so you don't have to go through the whole process again)
Hope this helped and/or advised you on your next move.Please rate my solution, thanks in advance. Wish you good day
Adzic A.
Memory stick pro duo reading problem
Usually that means there is a problem with the memory stick itself. Try replacing or buying a new memory stick
Ok i was trying to put music in my Sony Psp and a orange light keeps blinking on the side where the Memory Stick is.I tried everything but noting is working.Do i have to buy another one?
NO when you connect your psp to your computer it has to be in usb mode when your on the main screen of your memory stick make a folder inside that says MUSIC with all capitals you drag your music there...some songs CANNOT be read like wma format it has to be mp3 thank you.. hope this helped
The psp says, no memory stick inserted and everytime i insert it, the orange light just blinks continously! please help its 4gb and expensive!
I had this problem. 1 day it was working then it wasnt. Re format it in windows as NTFS then move it to your psp and reformat it there. Hope this works for you
1helpful
My psp 3000 cant detect my 8GB memory stick
try connecting it computer and do a virus quarantine and some times i also see this problem when u insert a memory stick the orange light will only blink and when you go to any option you get that it is empty first do this take out the memory stick and put in the memory stick and while putting the ms to the psp kepp pushing the ms to the psp then you will see the orange light blinking and after the blink stops take your hand off and that will be OK
4answers
My psp fell and now games from memory card are not loading
Did you try the memory card on another PSP? Or try another memory card in your PSP? If your memory card works in another PSP, then there's a problem with your memory card reader.
If you have a PSP-1001 model, it's not your motherboard but the circuit board that holds the memory cards.
If you have a PSP-2001 or PSP-3001, the memory card reader is a part of the motherboard and they are correct -- bad motherboard.
Memory stick unreadable by psp
try formatting the memory card via a card reader..
thats all i can think of
good luck!
Memory stick does not work
Use a Card reader to format your Memory stick and then put it back to your PSP and again format. Some times the PSP wont recognise memory stick and contents in it.
Top Video Game Consoles & Games Experts
Aron
john h
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
