Question about SanDisk Sansa m250 MP3 Player
Can't view any files on SanDisk Sansa M250 player with Windows 7
I recently got a new computer running Windows 7. Since then, I can't edit, change, delete, or even view any files on my SanDisk Sansa M250 player! (Which I had put on the player when I was using Windows XP). It shows that the player is almost full (which it is), but it does not show any files, so I can't delete or add anything to the player! I checked to see if there is a specific driver for Windows 7 that I am missing, but everything I can find just says that it is already compatible, though obviously it's not!
Help! Thanks!
SOURCE:
SOURCE: Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
Posted on Sep 06, 2006
SOURCE: Sansa M250 Freezes Upon Power UP
No solution. I'm sending mine back to Amazon for refund hopefully. 3.5 hours after opening the package it froze for me. It's now been 4 hours since I opened it. It has been frozen for at least 10 minutes since the last time I tried to turn it on. I tried reinserting battery, leaving battery out for a few minutes, plugging into USB when off, then when on. Nothing works. It starts "initializing" then goes to SANSA screen with V4.0.44A at top and m250 2.0GB at bottom. That is where it is still now more than 12 minutes later. How can I upgrade firmware if it is frozen? Read reviews on AMAZON, it is common. I have purchased electronics for over ten years. This is my first lemon. And I had an eMachine PC in 1999. And IT worked. I didn't short it or anything (the SANSA). It just stopped working suddenly.
Posted on Jan 23, 2007
SOURCE: deleting files that were already on my sansa c140...
reformat the player it will clear it all up
Posted on Nov 08, 2007
  • 7 Answers
SOURCE: sansa - sandisk m250 troubleshooting
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstall the battery without pushing any further buttons.
  2. Plug the Sansa into a computer, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. This solution has worked for me.
I do not know if this will work on other Sansa m200 type .mp3 players.
Posted on Jan 10, 2008
  • 758 Answers
SOURCE: drivers of sandisk sansa c250
Just follow the link below..Select your model number from the list
http://www.sandisk.com/DriverDownload/index.asp
Please rate accordingly
Thank you
Computerrep
Posted on Mar 24, 2008
How can i erase music from my sandisk sansa mp3 m250?
Please connect your player to the PC as it will be detected and the files shown on the window of My computers as the new drive. Now click and open all the files present on the player. You can easily click on the files to deleted.
Jan 21, 2011 | SanDisk Sansa m250 MP3 Player
How to format sandisk m250 using windows 7 media player
you dont need to use windows media player just go to my computer and rigth click on the mp3 icon and chose format
plese rate my solution
Jan 02, 2010 | SanDisk Sansa m250 MP3 Player
Sansa m250, can not see the files nor delete them
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the SanDisk website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Sep 29, 2009 | SanDisk Sansa m250 MP3 Player
Sansa m250 2GB can not see any files or play
I had a similar problem.
This is how I fixed Sansa m250 2GB
I have Windows XP, so if you have a different version of Windows you might have to do something else.
Connect the player to your computer.
From My Computer open the drive that says SANSA M250
If there is no folder called "audio" make a folder named that. (this is where your future mp3 files will be stored).
My audio folder was missing, so I had to do this.
Now go back to My Computer right click on the SANSA M250 drive scroll down the menu and open the folder that says "Open As Portable Media Device".
Now click on the icon that says "SANSA M250"
Now open the folder that says "FOUND.000".
If you are having the same problem that I did all your old mp3 files will show up with a file extension .CHK instead of mp3 and the names will be numbers. You can either erase all these & reload all your songs into the "audio" folder I mentioned previously or you can rename each file extension to a .MP3 instead of .CHK. (after you change them to .MP3 they will load on your mp3 player. But, remember if you do choose to rename them instead of erasing and reloading, when you want to permanently delete them you will have to access the "FOUND.000" folder again to do that.
Dec 07, 2008 | SanDisk Sansa m250 MP3 Player
Mp3 vs mp4
Hi Richards147,
Have you tried importing the file from your PC to the Sansa m250 directly rather than from iTunes?
You can also try converting your mp4 files from iTunes into mp3.
You will need to re-import your original files into mp3 format. You will need to change also your import settings to Mp3 encoder on iTunes. You can find this by choosing from the Menu bar of iTunes "Edit--->Preferences--->General---->Import Settings--->Import using : Mp3 encoder.
Regards.
Oct 18, 2008 | SanDisk Sansa m250 MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP#
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstalling the battery without pushing any further buttons.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
Dec 30, 2007 | SanDisk Sansa m250 MP3 Player
Sansa - sandisk m250 troubleshooting
Dec 20, 2007 | SanDisk Sansa m250 MP3 Player
M250 sandisk
Dec 13, 2007 | SanDisk Sansa m250 MP3 Player
M250 does not recognize some songs in the playlist
Use Windows Media Player to do this, not winamp
Nov 03, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
421 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
