Question about NetGear DG834G Router
I use Netgear DG834G with AOL9 Windows XP. Recently a number of sites are very slow to load or stop loading. I have been advised to change the MTU size to 1350. However when I try to do this the site does not load.
  • Thomasina Apr 02, 2008
    I have tried changing the MTU value from 1350 up to 1492 with no result I have noticed that on the sites I have a problem with I can get a site to load without a lock symbol appearing but as soon as I go to a new page the lock appears and it stops loading. Thank you for your help.
    Scholar:
  • 53 Answers
Try changing mtu to 1492
Posted on Apr 01, 2008
    Brigadier General:
  • 6,966 Answers
I am surprised that that you were advised to change MTU to 1350, it should normally be 1500 or at least 1450.
Have you done a Network repair? Right click on the networking icon in your system tray and click on Repair. Alternately, you can open a command prompt and type "ipconfig /fulshdns" and hit the enter key.
I wouldn't suspect your networking since some other sites presumably loads correctly and quickly enough. Perhaps what could be done is to tweak your networking connection both on the WAN side and the LAN side. Some utilities could do this for you instead of manually working on your registry. Some examples of tried good networking utilities are DRTCP.exe and TCPOptimizer.exe. You can do a Google for their download.
Additionally, WEP and WPA security have been known to slow down WiFi connections. Further using static IP addresses in your LAN would also be of help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE:
Slow for donlwad for netgear dg 834 g
open the netgear smart wizard page(www.routerlogin.com).The username-admin and password-password(default).In the netgear page at the left side blue screen click on wan setup under advanced menu . 1.check mark the disable spi firewall box 2.change the mtu size to 1350. 3.If these steps doesnt show any improvement then your firmware version might be older version so upgrade the new firmware in router upgrade. This will solve your issue if not it can be browser try new browser.hope i have helped you. Rate me if my solution was helpful.Have a good day
Oct 04, 2009 | NetGear DG834G Router
Netgear wpn824v3 slow connection, etc
MTU Adjustment
1. Access the web-based utility of the router.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
2. Adjust the MTU setting.
a. Click on the WAN Setup under Advanced tab.
b. Lower down the MTU size to 1492, 1400, 1358 or 1300.
c. Click on the Apply button.
Note: You may verify from your ISP the recommended MTU size you can use.
May 02, 2009 | NetGear RangeMax WPN824 Router
Netgear DG834PN: websites won't load
It's possible that this relates to your MTU settings. A clue to this is if you cannot access secure sites, or sites such as Ebay, Amazon, Google News, MSN, Hotmail.
If this does sound like your problem, try downloading the TCP Optimizer from Speedguide.net. This gives you an interface to examine and change your MTU settings (choose 'custom settings').
You might want to experiment by reducing your MTU, either in stages, or straight down to (say)1450.
For a full explanation of why you would do this, and how, check this page at the Netgear knowledgebase.
This may solve your problem, if MTU settings are the cause. However, if you choose to go ahead, please check out the warnings on the knowledgebase beforehand.
You are an expert user, so you will have set a rollback/system restore point in case the program or settings do not work for you.... :)
Nov 21, 2008 | Linksys Instant 802.11b Wireless Network...
Netgear DG834G unable to connect
Usually you have to use the software on the disk to open your web browser to http://192.168.0.1 or http://192.168.1.1. Then you can enter the administration username and password to change the settings.
Oct 08, 2008 | NetGear DG834G Router
Router problems
Try changing the MTU size of the router.
Set the MTU for cable connection to 1500/1400/1300
For DSL use 1492.
Apr 13, 2008 | NetGear RangeMax WPN824 Wireless Router...
First use the Netgear setup wizard:-
Open Internet Explorer
Enter http://routeraddress e.g http://192.168.0.1
Click Setup Wizard (top left)
Then for With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It should search for your connection, find it and allow you to log on.
Feb 06, 2008 | NetGear DG834G 54 Mbps 802.11g Wireless...
Netgear DG834G Setup
Hi Tradeboy,
This link should walk you though it, step by step!
http://www.geekgirls.com/windowsxp_home_network.htm
If you are using Vista, you will probley want this link, too. Click on Network icon.
http://windowshelp.microsoft.com/Windows/en-US/default.mspx
In the past I have found the biggest issue with networking is firewalls, so I suggest you disable them just for testing and setting up your network.
Good Luck
Jan 11, 2008 | NetGear DG834G Router
I have 20mb broadband but only 300kbs download speed
I personally have never known that changing the MTU setting can speed up your connection, as the MTU is the maximum transmition units that is sent to your pc from each web site and if the MTU setting is incorrect then some web sites will not load on your explorer page, the speed at which you download the page will not make any difference.
If you are supposed to get 20MB speed then you must be on cable and not ADSL as ADSL is a max of 8MB, so i would ring up Virgin or whoever and check the speed you should really be getting.
See these details posted on the netgear site, and you'll notice there is no mention of speed:-
Details About MTU
A packet sent to a device larger than its MTU is broken into pieces. Ideally, MTU would be set to the same — large — value on all your computers, routers and switches, as well as on all the parts of the Internet that you access. But you cannot control the MTU on the Internet, and in practice the optimum MTU size on your LAN is related to your hardware, software, wireless interference, etc.
  • Tweaking MTU size may work well in one situation, but cause performance and connection problems in others.
  • When network devices with different MTU settings communicate, packets are fragmented to accommodate the one with the smallest MTU.
  • Windows XP sets MTU automatically, that is, it optimizes computer MTU for you. This Microsoft article explains resolving lack of connection to a broadband ISP using Windows XP: How-To Configure Broadband Connections Using PPPoE.
  • Once a network device fragments a packet, the data stays fragmented until arriving at the destination computer.
Setting MTU size is a process of trial-and-error: start with the maximum value of 1500, then reduce the size until the problem goes away. Using one of these values is likely to solve problems caused by MTU size:
  • 1500. The largest Ethernet packet size; it is also the default value. This is the typical setting for non-PPPoE, non-VPN connections. The default value for NETGEAR routers, adapters and switches.
  • 1492. The size PPPoE prefers.
  • 1472. Maximum size to use for pinging. (Bigger packets are fragmented.)
  • 1468. The size DHCP prefers.
  • 1460. Usable by AOL if you don't have large email attachments, etc.
  • 1430. The size VPN and PPTP prefer.
  • 1400. Maximum size for AOL DSL.
  • 576. Typical value to connect to dial-up ISPs.
Nov 22, 2007 | Microsoft Windows XP Home Edition
Can't get internet access through NetGear DG834G Router
You have to configure your router...
If your ISP provided you with IP Address, enter the assigned IP address, subnet mask, gateway IP address anbd DNS IP address for your broadband router.
If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must enter the required information.
Hope this could help..
Mon =)
Nov 15, 2007 | NetGear DG834G Router
Netgear router dg834gt
Have look in the router settings for the actual internet connection speeds, as these are a more true reading than the speed check as the speeds can vary at different times of the day and 2 or 3 speed checks can bring different results. your actual connection speed that is showing in the routers settings is the connection you are getting from your ISP. If you are with BT they usually recommend using their latest routers, why i'm not sure, as the only thing i have noted is that the MTU is set at 1500 (Maximum Transmition Units)and in other routers the MTU is automatically set at 1493, so look for the MTU setting and up it if necassary, but not above 1500, also double check all the settings, even put the bt router back in and see if speeds improve, if, you know the BT router is set up purposly for faster connection speeds. Also try checking your speed at a speed test site at a quieter time of day, you will also see different speed check sites give you different speed results.
Jun 18, 2007 | NetGear DG834G Router
NetGear DG834G Router Logo
175 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
