Formating There are problems occured which i cannot detect.After start it shows a message to scan. But i am in delema what should i do.
  • shitikantha Apr 01, 2008
    Plese help me soon.
  • 13,434 Answers
You get a error on format what error can you post the error here.
Posted on Apr 01, 2008
SOURCE:
My 2005 GMc envoy stopped when I stopped at stop sign the service brake system warning keeps coming on when push brake pedal. Gear shifter won't move out of park and it will not start.
Hello Kammy ,you have electronic problems ! Your best bet would have it towed to a qualified repair shop .
SERVICE BRAKE SYSTEM
Refer to Brake Warning System Description and Operation !
The instrument panel cluster (IPC) illuminates the brake warning indicator when one or more of the following occurs:
• The body control module (BCM) detects that the park brake is engaged. The IPC receives a class 2 message from the BCM requesting illumination.
• The electronic brake control module (EBCM) detects a low brake fluid condition. The IPC receives a class 2 message from the EBCM requesting illumination.
• The EBCM detects an ABS malfunction which disables dynamic rear proportioning (DRP). The IPC receives a class 2 message from the EBCM requesting illumination.
• The IPC performs the bulb check at the start of each ignition cycle. The brake warning indicator illuminates for approximately 3 seconds before turning OFF.
• The IPC detects a loss of class 2 communications with the BCM or with the EBCM.
When there are electronic problems the computers will not allow the vehicle to start , hooking up a factory or professional scan tool to see what the problem is is the first place to start .
Apr 14, 2017 | 2005 GMC Envoy
My pcg-8z2l shows multi coloured lines while booting.Immediately after i have signed in my user account,it shows a message that winflip 3D setting failed to start,then it shows a blurred...
run a boot time scan.. that will find out what the problem is.. if it is a software problem.
If its a hardware problem then the boot time scan should detect it and try to fix it.
Aug 08, 2013 | Computers & Internet
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I got Kingston DTI/64GB, when I insert in my PC - having windows XP- message occurs for FORMAT - I click on OK button, Format window open - Capacity shows 62.4GB, System= Nill, I select Quick format option...
first try to format in command line
Start
go to RUN
Type CMD and press enter key
in command window type format H:/fs:FAT (H: stand for my Pen Drive name change it if you have different)
press enter key
yes to all message appear
now you formatting start
if not so try this: 1000% work
download any low level formatting system and format from that or you need 3rd party formating tools like HP format tool to format RAW to FAT,
if still not work it mean your PEN Drive got Damaged and you have to purchase a new one.
Do vote me if this help you.
Jul 27, 2011 | Computers & Internet
Paper jam message is showing but nothing is jammed in scanner and it will not pull the paper through
Hi
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Hope the above info is helpful.
Please check your device first and get back to me.
Thank you.
Regards,
Tech Satya
May 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
Check engine light is showing and car will not start
The check engine light comes ON,when there is error code stored in the car computer. to get car scanned at diagnosis center to get error codes, At diagnosis center you will receive the error code.As per the error code it will detect the exact faulty part in the car due to which the problem is occurring.For more help :--- at www.autozone.com its absolutely free to get car scanned.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
May 15, 2010 | 1996 Hyundai Accent
My 4GB pen drive is not formating...
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
Jun 26, 2009 | RCA TH1101 MP3 Player
I WANNA INSTALL XP2 BUT MY SYSTEM SHOWS ERROR: C000022UNKNOWN HARD ERRORSYSTEMROOTSYSTEM32NTDLL.DLL
  1. This problem may occur if the file that is described in the error message is corrupted. The following files are checked for integrity when Microsoft Windows XP starts:
  2. All driver files (except those that are loaded by the system loader to start. the computer)
  3. All dynamic-link libraries (DLLs), including User, Graphics Device Interface (GDI), Shell, Kernel, Ntdll, Crtdll, and others.
  4. This problem may occur if you install an inappropriate driver for your hardware. For example, you receive one of the error messages that are described in the "Summary" section if you install a MIPS driver on an X86-based computer.
    This problem may occur if an Iomega Zip drive is on the same integrated device electronics (IDE) cable as the hard disk drive.
  5. To resolve this problem, obtain a new copy of the corrupted file or reinstall Windows XP. If you continue to receive any one of the error messages that are described in the "Summary" section after you reinstall Windows XP, a hardware problem or a network problem may exist.
  6. This error message may be displayed in many different formats, including an error message that is displayed on a blue screen or an error message that is displayed in a dialog box. The type of format that the error message is displayed in depends on how much of the operating system was loaded when the corrupted file was detected.
Apr 11, 2009 | Microsoft Windows Vista Ultimate Edition
Message showing - player problem connect pc and fformat player
i have philips gogear sa 1356/97 mp3 player.it is not working .when i switch on the player a message displays "Player Problem-Connect to pc-format player". My PC not detecting the device.
Jan 19, 2009 | Philips GoGear SA1350 MP3 Player
Open Questions:
Computers & Internet Logo
24 people viewed this question
Ekse
Alun Cox
