Nad 317 Amplifier No sound
I have bought this from a second hand market.Theres no output.
When switched on it clips in and out.Everything seems to work fine but no sound.Have checked the fuses and both ok.
There is sound from the headphone input at the front.
I did not get the remote control.
Any ideas please on what to check ?
  • 54 Answers
Could be the speaker output relays. GOOD LUCK
Posted on Apr 02, 2008
NAD C320. Only one channel sounds. Problem with the volume control?
Did you try to switch the loudspeakers? Before changing anything always lover the volume and switch off the amplifier.
Assuming you tested already different inputs, you can be sure no cable from signal source is out or defect. (or did you nit check that first?).
When the amp is switched off, disconnect the speakers and switch left to right and right to the left output.. If the other speaker is quiet now, you are sure it is in the amp. Still his can be anything.
You can check the connections between the pre and main amplifier on the back side. When you have an extra set of interlink cables, perhaps you can cross the in and output there too. Take care every time you change something, lower the voltage and switch off the amplifier. Sudden clicks when switching on or changing anything can damage the amp and or the speakers.
Perhaps when you checked this you can locate where the problem is? Speaker, speaker cable, power amp, pre amp, (only a part of the pre amp.
Nov 12, 2013 | NAD C320 2-Channel Amplifier
Nad 317
Check for leaky output transistors change emitter resistors
Jul 29, 2013 | NAD Audio Players & Recorders
Sound distortion with NAD T 514...
You are probably clipping in that midrange. Since the DVD player is fine and CD player is distorting: they are line level outputs, If you are running those through an equalizer- the equalizer should allow you add in a 10db attenuation.
If you are running them straight to the amp, The CD line level output should be about 1.5 volt peak to peak, it may be the line level input of your amp is only 1 volt and the DVD player simply has that level of output so does not clip..
Simply adding into the cable a 0.1 microfarad polyester capacitor for each channel should be enough attenuation to avoid clipping. The midrange is where you hear the most content in large part because that is the range that the human ear is most sensitive to. Which is why that portion clips. The DVD audio is actually recorded to the same specs as CD audio. You can confirm this by playing your CD disk in your DVD player. .
Sep 25, 2012 | Audio Players & Recorders
NAD C350, everything works after i replaced many blown parts except it has no sound output from any channel, just need some ideas on what to check for faults. thanks
With no background on the original problem and no details regarding what parts were replaced how can anyone answer the question?
What exactly does it mean if 'everything works' but it has 'no sound output'? As a two channel amp that would be its ONLY function.
The root cause for 'no sound' could be something as simple as a misplaced control (Tape Monitor?) or missing pre-out/main in links. It's in the manual.
Register and download it for free at
Jun 01, 2011 | NAD C350 2-Channel Amplifier
No output but all checks seem positive
You should hear 2 when you first turn the unit on, and a second one about 5-20 seconds later. I'm going to guess you don't hear the second click, which means that your NAD has DC Offset, meaning a damaged amplifier.
May 19, 2010 | NAD C352 2-Channel Amplifier
Excess clipping on nad 372 amp
อิอิ ขอบคุณคับ
May 24, 2009 | NAD C272 Amplifier
Sound through one channel only.....NAD 310 Amplifier
If swapping of left and right input sources and left and right speakers does not might have a bad channel in your amp.
Sep 24, 2008 | NAD Audio Players & Recorders
NAD C370 Amplifier
This sounds like a problem with the protection circuit, and/or the speaker relays. More specifically, a capacitor within those circuits that is not behaving properly. I strongly suggest having it looked at ASAP.
Sep 15, 2008 | NAD C370 2-Channel Amplifier
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
Power but no sound
The cables going from the pre-out to main were just loose enough to cause the problem
Apr 19, 2008 | NAD C370 2-Channel Amplifier
394 people viewed this question
