Question about Dryers
Banging noise My Whirlpool dryer was making a banging noise. Replaced a part that looks like a black wheel ( rear bearing?) but when we put the dryer back together it doesn't turn on? What did we do wrong?
    President:
  • 1,314 Answers
Check the door switch to see if you forgot to plug it back in llet me know
Posted on Apr 01, 2008
SOURCE:
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
How do I fix my whirlpool cabrio dryer model wed6200swi so that it stps the noisy squealing sound when it runs?
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Mar 04, 2015 | Whirlpool Dryers
Asko dryer make a banging noise
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Oct 02, 2014 | Asko Dryers
Dryer shutd off.
see the next steps and fix it. God bless you
Not all will apply to every dryer. Check our video page for more style dryers.
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. You will need to disassemble the dryer to check these. Some dryers use rollers in both the front and rear.
Belt
The Belt should be replaced if you hear any noise coming from it or if there is any cracking, glazing, or grooves worn out.replace the belt along with the idler pulley.
Idler pulley
Dryers have a tension or ideler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace the glides and bearing houses if necessary. Put hand inside drum near front and push up there should be no play.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace the rear bearing when they're worn. Put hand inside drum near rear and push up there should be no play.
Blower wheel
Your dryer's blower whells pulls air over the heat source, through the clothes drum, and past the thermosta ts, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace the blower whell Many times the blower wheel is making the noise and it is commonly mistaken for the motor.
Motor
The motor may be making noise. The easy way to check is to remove the belt and turn the dryer on if it is noisy replace the motor
Jul 09, 2013 | Dryers
I'VE GOT A WHIRLPOOL STACKING WASHER DRYER COMBO BOUGHT APPROX 2002. wASHER WORKS FINE, pUMPS WATER OUT FINE BUT ON SPIN CYCLE SEEMS OFF BALANCE AND MAKES ALL KIND OF BANGING NOISES. i EVEN TRYED SPIN...
Transmission bearing has failed. The transmission has to be replaced as a unit.
The transmissions are relatively inexpensive (around 150 to 175 dollars) I have replaced 3
of these and they are rather difficult.
Apr 12, 2011 | Whirlpool LTE6234D Top Load Stacked...
My GE electric dreyer, DHDSR46EGWW, is making squeaking noise and a grinding noise. My husband took is apart last night and put back together. When he started it the noises came back and he said it...
It could be the rear bearing or if not it have your honey take it apart again and inspect the rear rollers, if they turn freely then inspect the front bearing assy it is on the the door and if it looks worn down then it is allowing excessive pressure on the rest of the unit .
Apr 01, 2011 | General Electric DHDSR46EGWW Dryer
I have a LG dlg5988w drying that just started making a banging sound. Are there rollers that need replaced?
yes the belt has a tensioner with a bearing and a roller surrounding the bearing
the bearing can be locked up which will put flat spots in the roller m,aking the banging noise
Sound horrifying at times doesn't it?
Mar 07, 2010 | LG DLG5988 Gas Dryer
Noise in dryer
Does the drum turn smoothly, or does it bounce around? If it bounces, it could be the bearings in the drum wheels going out. The wheels would need to be replaced ($20 on up).
Jul 03, 2008 | Maytag MDG9206 Dryer
Whirlpool Imperial Dryer Model #LAE8800A0
these bearings are dry plastic pads if i am, correct, these can be lubricated very slightly with a little silicone grease where they are rubbing on when the drum rotates
if you cant use silicone grease, more or less any will do that is thick and doesn't smell, only use a very small amount so it doesn't go on the clothes
a very small amount is enough to stop the pad being dry but not enough to see? almost like wipe it on then wipe it off,
also lubricate the the pulley wheel on the belt tensioner (the little small wheel at the bottom if it has one
Oct 13, 2007 | Dryers
Dryers Logo
140 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
