Question about Fuji FinePix S5000 Digital Camera
Appear on and off automaticlly when turn camera on
Please give some solution of this problem. when i turn my camera on its automaticlly turned off and than start automatically on and off.
Regards
S.Hamid
s_hamid80@hotmail.com
  • hano Apr 01, 2008
    Hellooo
    thanks for your solution. but i am little bit confuse that as per u which i understand its hardware problem right so i have to visit fuji showroom for repairing?
Hi! I have a Fuji s5000 model, i'v had it for a number of years, and i had the same problem for a while, until i got it fixed and the problem was - the censor under the on and off switch was slightly worn down, so when you shifted the on switch, the censor would also twist, which eventually snaps it and you'll need a new one!
cya
Posted on Apr 01, 2008
The lens is stuck open and when I turn the camera on it says lens error will shut down automaticlly restart camera
Try moving around the lens GENTLY. If does not help, call Canon, they will probably fix or replace it.
Aug 29, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Canon EOS Digital Rebel XTI 400D Displays Err 99. Problem with CF card. Replaced with brand new card-still same err 99 camera is totally charges, acts dead, keep flashing Err CF, I try to format, it...
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Aug 31, 2008 | Canon EOS-20D Body only Digital Camera
I CAN'T DON'T KNOW HOW TO TURN ON THE FLASH.
To turn the flash ON please follow the instructions below
  • Raise the Flash
  • After pressing the tinualbinale_1.gif button turn the mode dial button tinualbinale_20.jpgon top to choose tinualbinale_16.jpgsymbol.
  • Then press the FUNC.SET tinualbinale_17.jpg button.
  • Once set, tinualbinale_18.jpg symbol will appear. Now the flash is turned on.
Jun 04, 2011 | Canon PowerShot SX130 IS Digital Camera
Appear on the screan" please turn off and turn on
It appears to be a lens issue. Contact Panasonic Support to get this fixed, as opening your camera can cause more damage than it already has. Here is the Panasonic Support Site: http://www2.panasonic.com/consumer-electronics/support
Feb 18, 2011 | Panasonic Lumix DMC-FZ20 Digital Camera
I installed a new Mark II .3 hp sump pump to replace one that is old but still works. The float doesn't automaticlly turn the pump on. The float works if I hold it completely upright. The flot goes up and...
It would appear this float requires a steeper angle to operate. Is it possible for you to mount the float cord lower or shorten it? By doing so it will close at a earlier time starting the pump. THis may be done with the use of some electrical (zip) ties.
I hope this may have assited you,
Tom
Jul 23, 2009 | Plumbing
ERR 99
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I am getting an error cf..tried to format card and get error 99
I Googled the error code you're getting, and found a list of things to try and steps to attempt directly from Canon. Try out some of the stuff below, it should help.
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 300d gives error 99 and does not work
Try the following diagnosis steps: -
Nov 28, 2008 | Canon Digital Rebel / EOS-300D Digital...
I have error 99 in my camera canon 400d
Ifd the camera is only 3 months old - return it for replacement
Sep 01, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Fuji FinePix S5000 Digital Camera Logo
32 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
