Question about E-Machines eMachines Desktop PC
Emachines D845GVSR motherboard repair
Hi, I have an emachines 2210 with intel D845GVSR board. The power supply failed and damaged the motherboard - is there any chance the board is repairable? A working psu from another computer has been fitted but the psu fan does not run, there is no bios beep, and only the green 5v standby led lights on board. I would be very grateful for any suggestions you can offer. Thanks, Alan.
  • 152 Answers
Your i/o controller ic {SMSC} fail or rtc circuit fail there is two most possibility
Posted on Apr 02, 2008
E-machine T2984 Motherboard replacement
The eMachines T2984 uses an Intel D845GVSR motherboard,
http://www.ebay.com/itm/Intel-D845GVSR-Socket-478-Motherboard-Warranty-/261132348848?pt=Motherboards&hash=item3cccb36db0
Just one example from a quick search.
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
The above is the motherboard manual -
Intel Desktop Board D845GVSR Product Guide (PDF)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 24, 2012 | Computers & Internet
Fan Speed 100% on Intel D845GVSR motherboard
see if you plug them in the right spot cpu gose by the cpu case fan will say case on board some take two wire fans some 4 wire some 3 wire jim
Feb 20, 2010 | Intel D845GVSR Motherboard
E-Machine PC with only a green LED on MB on Boot attempt
We have repaired many of these systems. The board was damaged when the power supply shorted. You can get replacement motherboards at www.barebonekit.net click on the link on the left side for motherboards and look for Emachine.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 16, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
I have a emachine PC. PowerSupply blew up. changed it still down
Dear,
ELECTRIC SHOK OR IMPROPER EARTHING IS DAMAGE POWER SUPPLY,MOTHERBOARD,PROCESSOR,RAM
HOW TO CHECK IT.
(WHEN CHECKING KEEP CAUTION :- REMOVE HARD DISK DRIVE POWER SUPPLY SOCKET)
1. check power supply watt 400/450 and same another power supply install and check it. if power supply change and system is working ok so problem in your power supply.
2. check CMOS cell on motherboard,(3 volt)
3. Bfore power supply changing check on mother board any capasitor is like as damaged or not.
OR check main chipset ic is marked as intel.whenpower on it is very hitting or
normal)if very hitting require to repair your motherboard.(intel chipset ic near cmos cell or pci slot,)
4. checking of ram on other pc (working or not)(one beeps coming or not,if one beep coming ram is working ok)
Feb 27, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Emachine T3828 power switch connection to motherboard
The "Ultra Helpful Instructions" that Emachines provide (here: http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf) state that when replacing the system board, "18. Attach all cables to new system board", but fails to say where that would be for each cable.
The site below says it's a genuine Intel board in there, so, congrats on that. http://www.e4allupgraders.info/dir1/motherboards/socket478/D845GVSR.shtml
And with that, the link to the manual:
ftp://download.intel.com/support/motherboards/desktop/D845GVSR/SR_English.pdf
You're looking for the info on page 32, I believe.
See if that fixes it up. If not, post back.
Jan 03, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Intel d845gvsr
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
108
Jul 08, 2008 | Intel D845GVSR Motherboard
Motherboard taken out by eMachines Bestec power supply
I have not identified the specific components on the motherboard that blow, but I can tell you the defect in the Bestec supply. The +5 VSB, which is the voltage that is on at all times, loses regulation and climbs to 8-11 volts. I believe this "higher than the required" +5V takes out the components on the motherboard involved with the computer/power supply "turn-on" circuitry. The "on" button on the eMachines front panel no longer turns the motherboard on because the "kept alive when the main power is off circuits" - which allow the on/off button to do its job of turning on the machine - no longer work.
Test your Bestec power supply by plugging it in the wall socket and have it not connected to anything. Read the voltage between the purple wire and any black wire. If you see +5.0V, then this wasn't your problem. If, like it did on mine, is closer to between 8, and 11 V, this is what took out the motherboard.
Jan 06, 2008 | Intel D845GVSR Motherboard
Emachine T2742 MB D845EPI/D845GVSR
The diagram for that 9 pin J9G1 is alongside the CMOS battery.
Dec 25, 2007 | Intel Desktop Board D845EPIL Motherboard
E-Machines eMachines Desktop PC Logo
139 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
