Question about HP DeskJet F380 All-In-One Printer
Scanner I recently installed this printer to my compaq presario V2069CL laptop The problem i am having is that when I scan a document I have typed in Microsoft Word, there are characters that appear on the document scan and the document appears too close to the left and there is blank space to the right side of the page. Every thin out of line. When the original document was typed margin settings were correct and everything is in order. I have tried making sure language is in english.
  • HP Master
  • 13,433 Answers
Seems to me you havent inserted the paper to the scanner correctly, i have f380 right next to me and never had such a problem.
Posted on Apr 01, 2008
How do I scan a document to my computer
It depends on the type of scanner you have, but most of the time it's as simple as plugging the scanner into your computer, laying the document on the scanner surface, closing the lid, and then pressing "scan" in the scanner's software - provided that you have it installed.
If you don't have any scanner software installed, it's likely on a disc that came with your scanner.
Sep 27, 2014 | Office Equipment & Supplies
Scanner won't work with compaq cq58
You orobably do not have the required drivers for the scanner. I suggest you to browse the manufacturer's website and download and install the latest updates from there. Also if they recommend any utitlity along with driver intall it and then try to scan the document. This will hopefully resolve the issue.
Sep 19, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
I recently bought a Canon PIXMA MX320 all in one printer with my macbook. It works fine, but I can't figure out how to scan an image onto my laptop.
You need to control the scanner through your PC with canon software that came with your scanner otherwise you cant scan anything..first open the printer/scanner software ,select scanner,then place your document and command "scan" from the software.
Good luck, do rate the solution if helped
Nov 27, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
I want to upgrade the RAM in my Compaq Presario V6133CL, but the manual doesn't say, which type of memory i can use. The Product Specifications on...
If you go to give permission and it will scan your computer and tell you anything you want to know about your memory installed also normally gives you upgrade options as well
have fun
Nov 13, 2010 | HP Compaq Presario V6133CL Notebook
How do you scan a document on the rx425
I hope you have installed the MFD on your PC/laptop. If yes then do the following: Start the word processor (MS Word or whatever you use). Start the document and when there is need for the scanned document, insert the document in the scanner and go to File->Import. here you will get a choice of using the scanner. Do that. Alternatively, start the SW that got installed with the scanner. there you will find an option for Start Scanning..
Nov 09, 2009 | Epson Stylus RX425 Multifunction...
How do i scan a document and then email it
If you haven't done so, install the cd that comes with the HP Officejet package. Once correctly install, you should go to "All Programs" and locate "HP Solution Center" Click on HP Solution Center, click "Settings", click "Scan settings and preferences", choose either "scan document" or "scan picture" If word document then under File type: locate "PDF(*.pdf) If document is a picture then under File type: locate "JPEG image(*.jpg), click ok. Step 2 Choose between Scan Picture or Scan Document, click accept Step 3 your file is locate under "My scan" Hope that helps
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
As with most scanners, place the document in the scanner for scanning. Open the software that you wish to use. Select "File" from the menu and then "Import". Your scanner interface listing should appear. Click on the device to begin your import from your scanner. Your scanner should scan the document and it will appear in your application. Be advised, Scanners scan in a Graphic format. To edit in a wordprocessor you will need some kind of OCR (Optical Character Recognition) Software to convert the graphics into a wordable form for editing.
Jun 11, 2009 | Canon Pixma MP480 All-In-One InkJet...
How do I start scanning
what exactly u mean can u explain me clearly pls.....
Feb 18, 2009 | Compaq Presario V2401CL Notebook
Laptop shuts off without warning randomly
I know this may seem like a stupid question, but, is the battery charged good? Also, have you checked the contacts on the battery to be sure they are making good contact? Other than that, sounds like a thermal issue. Does the event viewer offer any explanation?
Nov 08, 2007 | HP Compaq Presario V2000 Notebook
HP DeskJet F380 All-In-One Printer Logo
37 people viewed this question
Ben Johnson
