BLACK OUT LCD DISPLAY AND PANEL NT FUNCTIONING
The machine is iR8500 canon copier. after using the machine for that hour the operator turn off the switch located in the panel, then a few seconds turn off also the main switch located at the side.
a minutes later he turn on the machine in the main switch but the lcd canot display now and also keypad of the panel not responding...
only the green LED function in the front...
what is the possible cause of the problem? and which is defective board or parts?
thanks
seems like a silly question, and i dont know about canon copiers, but on my toshiba, underneath the key panel there is a scroll button that turns the brightness of the lcd up and down, if hit by accident, as often happens the lcd appears black. It has tricked me before!! haha
Take care
Posted on Apr 02, 2008
Canon ir8500 E000019
That means the toner waste bottle is full. Located behind the panel on the right side of machine close to the rear. About 12 '' high or so. Turn off machine. Remove the two screws that hold the panel and remove the panel. Pull out the The plastic container you see which has toner inside which is no good and is waste. Empty it in a secure garbage bag etc so it doesn't get all over the place. Then replace the the container, making sure it is securely in place as it was before you started. Refit the panel and the two screws. Then Turn machine on.
Dec 12, 2011 | Canon imageRUNNER 400S Copier
What does error 000111 mean? in canon ir8500
Hello mks. This code means that the laser cooling fan(FM14) has locked and needs to be replaced.You may be able to remove it and free it up as it is most likey locked up.It is located on the front of the machine under the op panel.
Apr 21, 2010 | Canon imageRUNNER 8500 Copier
Why better canon ir8500 than canon ir7200
Features - The Canon imageRUNNER 8500 benefits from a number of unique features including 85 ppm output, 4 trays online, 100 sheet document feeder, digital copying, built in duplex , network printing/scanning option, professional image quality and compact and reliable design. The Canon iR8500 can copy or print up to A3 paper size. This high volume copier provides an easy and efficient solution for work groups.
Sep 06, 2009 | Canon Office Equipment & Supplies
Canon ir7200 or canon ir8500 which one is best to buy
for my choice will be Ir8500, tough and reliable machine and high speed printing.
Sep 06, 2009 | Office Equipment & Supplies
Ir8500 error code e000020-0010?
you have to clear this error by doing the following press additional function(*) and 2,8 together) then press additional functions (*)again (you have to do this quickly to get into service mode then you press copier
then you press function
then you press clear
then you press ERR
then you press ok
then turn off the machine and then back on
this is a low toner level detection code
do you have a new toner in the machine?
Aug 05, 2009 | Canon imageRUNNER 105 Copier
Keeps blinking E3
Hi. Canon says this
E, 3
Paper jam.
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press the Black or Color button.
There is another step to fix this, also from canon.
Issue: ERROR LED: E, 3
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Apr 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Canon mp830 error code 5010
Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
Nov 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
CANON iR C2105!! no display on the LCD!
try adjusting the contrast, open front door and look under the panel there should be an adjustment screw for the contrast, if it doesnt work I suspect it is the panel itself that is bad.
Sep 12, 2008 | Office Equipment & Supplies
"Put in cartridge" error message
Issue: ERROR LCD: PUT IN CARTRIDGE
Oct 20, 2007 | Canon PIXMA MP780 All-In-One InkJet...
E602 0001 - ir8500 Canon
Turn machine on while honding down the 1 and 9 keys.Machine will run a hardrive check program that takes 20-30 min.Power cyle main power in about an hour.If this dosn`t work system software and or new hardrive.$$$$$
Sep 17, 2007 | Canon imageRUNNER 8500 Copier
85 people viewed this question
k24674
jasbo
jasbo
