Question about Philips Magnavox Learning Universal Remote
NEED CODES FOR PHILIPS 3 DEVICE
NEED TO FIND CODE SHEET
  • Anonymous Apr 05, 2008
    remote code list for philips universal remotes
    Champion:
  • 207 Answers
Just follow the instructions on this page to find code for your device http://www.urc.philips.com/
Posted on Apr 10, 2008
I need the codes for PHILIPS Sru 2103/27 universal remote control for Philips tv
Hello
There is no manufacturer code given in its manual. But you can find out the code of your device to be controlled with this remote control.
Code search by Brand
Lets you search for a code for a specific Brand within
the Code Library for a particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the SETUP button until the red
indicator remains on, then release SETUP button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press and release the numeric button (0-9)
corresponding to desired Manufacturer (see table on
code list sheet). The red indicator blinks off once.
Note, pressing "0" performs a full library search same
as normal Code Search Method on previous page.
5. Press the CHANNEL UP button ((or POWER or
PLAY (VCR only)) repeatedly until the device to be
controlled changes channel. The red indicator blinks
off with each button press. If you accidentally
overshoot the code required, press the CHANNEL
DOWN button to backtrack through the library until
the device changes channel. Pressing CHANNEL
UP changes direction to forward again.
6. Press and release MUTE to install the code.
Brand Search Method entry is now complete.
Note: When all codes under a Brand have been searched
the red indicator flashes rapidly for 3 seconds.
Mar 10, 2011 | Philips Televison & Video
Ive lost my code sheet for my philips universal remote cl034 and i need the 4 digit code for my durabrand tv
DURABRAND .......... 0520 0115 0317 0916 0027 0447 0323
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Oct 13, 2010 | Televison & Video
Need to down load the codes i need to use with a dolby dvd player
http://www.p4c.philips.com/files/s/sru3006_27/sru3006_27_dfu_aen.pdf
That is the link to the manual if you need it. All the codes and information is on page 7
indicator stays on, then release the SETUP button.
2. Press and release the desired mode button (TV,
VCR, etc.). The red indicator blinks, then stays lit.
3. Enter the 4 digit code from the code tables (on
separate sheet). Note: after a valid code entry, the
red indicator turns off. For an invalid code, the red
indicator flashes.
4. With your device on, press CHANNEL UP. If the
device responds, no further programming is required.
Note: If some buttons do not operate your equipment,
try one of the other codes for your brand.
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
5. Press and release MUTE to install the code.
May 21, 2010 | Philips SRU3006 Remote Control
Lost code sheet
Try these: 3013, 3050, 3102, 3146, 3147, 3160, 3165, 3229, 3257, 3430, 3431.
Jun 16, 2009 | Philips Magnavox Learning Universal Remote
Manual
most of the philips remotes work the same way (excepted for the ones with lcd sreen).
1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
2. Press and release the desired mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
3. Enter the 4 digit code from the code tables (on separate sheet). Note: after a valid code entry, the
red indicator turns off. For an invalid code, the redindicator flashes.
4. With your device on, press CHANNEL UP. If the device responds, no further programming is required.
If you tell me whish devices you want to connect, I might have the code for you.
Oct 13, 2008 | Philips Magnavox REM-350 Remote Control
Need codes for a philips universal remote code sheet
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
Philips universal remote codes for symphonics tv
Hope this helps :)
Dec 22, 2007 | Philips Magnavox Learning Universal Remote
I need the codes
Here's how:
Turn on the electronic you will programming the code for.
Press and hold the CODE SEARCH button until the red indicator stays on, then release the COE SEARCH button.
Press and RELEASE the desired mode button (TV, VCR, etc.). The red indicator blinks quickly, then stays lit.
Enter the 3 digit code from the code tables.
With the device on, press CHANNEL UP on your remote. If the device responds, no further programming is required.
Panasonic DVD/VCR combo code: 345
Nov 30, 2007 | Philips PM4S Remote Control
Manually turn on the device you want to control
1. press and hold the CODE SEARCH button til the light stays on release the code search button
2. Press and quickly release the desired button ( TV, DVD, etc ) the red light blinks off once
3. Press the CHANNEL UP button repeatedly ( up to 300 times ) til the device changes channel and stop
(the red light will blink off after each time the channel up button is pressed )
4 Press the MUTE button to set the code
hope this helps
Nov 23, 2007 | Televison & Video
One more 'lost code list' person. I have a philips SRU 2040/17 universal remote and a sanyo tv. 'code seach' doesnt work, i need the actual 3 or 4 digit code. HELP! my kid wants to watch cartoons and i cant turn the tv from video back to cable.
Aug 22, 2007 | Philips PM3S Remote Control
Philips Magnavox Learning Universal Remote Logo
104 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
