Question about Dell 1703FPs 17" TFT LCD Flat Panel Monitor
Powering on my dell 1703FPs moniter comes on but then goes straight off again any ideas
  • denisr52 Jul 11, 2008
    I have the same problem with a Dell 1703FPS monitor. Turb it on and it automatically goes blank but green power button stays lit.
  • alard Feb 06, 2009
    Yep, same problem...
    Genius:
  • 2,785 Answers
Checked your monitor with a qualified proffesional.
Posted on Apr 01, 2008
I've upgraded operating system to Vista and can't find drivers for Dell 1703FPs
Have you tried to download from Dell support site. Support.dell.com
Eventhough it doesn't list Vista as an option it should work. XP 1703FPs
driver should work on Vista.
Jan 23, 2011 | Dell 1703FPs 17" TFT LCD Flat Panel...
I have a dell LCD model no 1703FPs monitor, whenever i power the screen its displays for about 4secs and turns black while the light indicator remains green indicating a video signal.
You may have bad backlight inverter board (shorted transistors, transformers, need test lamp to verify), or worst case the lamps assembly (need lamp tester to verify).
You can check and see if the power supply is putting out the 12vdc for the inverter board first and go from there.
http://www.lcdrepair.us/1703fps-inverter.html
http://www.lcdrepair.us/1703fps-power.html
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 03, 2010 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell monitor 1703FPs
you backlights are going off.y ou need to replace the power supply in this monitor very comon problem
Dec 30, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
My dell monitor 1703fps comes on for about 2 seconds
i think if you can service your monitor please see all the filter capacitor i think capacitors leak and need for replacement.
Sep 28, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
It goes into power save mode and won't come out.
Check your power save settings in Windows. It will be in control panels under Performance
Aug 12, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
http://www.lcdrepair.us/1702inverter1900x.html
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
Blank after 2 seconds
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
Jun 14, 2007 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Dell 1703FPs 17" TFT LCD Flat Panel Monitor Logo
347 people viewed this question
Alun Cox
