Usb cable not supported - Computers & Internet
I have LG C2500 cell phone.i need USB drivers to support comport to do browsing.
Posted on Apr 01, 2008
SOURCE:
My lg k10 2017 phone does not want to transfer photo's or music with cable from pc. error message : device has either stopped responding or has been disconnected.
Make sure that usb driver and GMobileSupportTool is installed on your PC.
1. Download Lg Mobile Support Tools using the link below:
http://tool.lime.gdms.lge.com/client/app/LGMobileSupportTool.exe
2. Execute downloaded file. Follow installation instructions. After executing LG Mobile Support Tool in Step2, you can download USB Driver:
img-mobile-support-nsatmeh50lx5u1woeaeqllmn-4-0.gif 3. Connect your phone to PC by using the bundled USB Cable
4. Click start updating
The phone software upgrade stopped before completion?
  1. Don't close the update tool, disconnect the cable and reconnect it. And check the USB Driver connection on our PC. After that, please restart the update.
  2. Otherwise, please select "Customer Support"-"Recovery Phone" in LG MOBILE SUPPORT TOOL. Then, you can start to recover your phone.
Mar 17, 2017 | LG Cell Phones
Not conect to computer with usb ctk 5000?
Unplug the USB cable.
Download correct driverfor your OS from
http://support.casio.com/en/support/download.php?cid=008&pid=20
You need to load the driver first and only plug in the USB cable when the software tells you to do so.
Aug 28, 2012 | Casio Ctk-5000 Electronic Keyboard Piano...
Hello! I turn on the printer with USB data cable atached to my pc and the Ready led is on. I installed the printer driver from lexmark support site everything beeing ok until now. I try to print from my...
Please try to switch to another usb port or try using a different usb cable. try to unplug and replug the cable and check if the computer was able to detect the printer.
For further assistance please contact Lexmark Technical Support
Aug 06, 2011 | Lexmark E321 Laser Printer
Trying to connect HP Laserjet 2100 (works fine with XP) to Pavilion dv7 with Win7 64 bit Professional. I downloaded the PCL5 driver from HP but it will not print. I am using a Manhattan parallel to USB...
Did you download the Win 7 64 bit drivers for this printer. If not i suggest try downloading the drivers from the following link
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=14914&pr...
Check the USB connection
The icon on the USB cable (c01424575.gif ) faces up when the cable connects to the product correctly. Check the back of your product and the back of your computer to make sure the USB cable connects correctly and securely.
After you make sure the USB cable connects correctly and securely, review the following guidelines to check other potential USB-related problems:
  • USB ports on the keyboard. USB ports on the keyboard and in the front of some computers might not be powerful enough to support the product. If the USB cable connects to the USB port on the keyboard, try connecting it to another available USB port on the computer.
  • USB cable length. HP supports USB cables less than 5 m (16 feet, 5 inches) long. However, a USB cable that is 5 m (16 feet 5 inches) long must be of high quality. Otherwise, HP recommends using a USB cable that is less than 2 m (3 feet, 3 inches). Do not use patch cables to increase the length of an existing cable. Use a powered USB hub if you need more length.
  • Alternate USB ports. Connect the USB cable to another port on the computer to make sure that the USB port on the computer is not the cause of the problem.
  • Defective USB cable. Replace the USB cable to make sure that the existing cable is not defective.
  • Conflicting USB ports. Disconnect any other USB printers, USB scanners, USB cameras, and any other USB connected peripherals. Start reconnecting these devices one at a time to determine if one of the devices is using too much power. Consider purchasing and installing a powered USB hub if necessary. NOTE: A USB-powered hub is a device that increases the number of available USB ports on a computer and facilitates communication between the USB devices and the computer. A powered USB hub can resolve communication failures between some, but not all, USB chipsets and HP products.
Jun 23, 2011 | HP LaserJet 2100 Printer
Printer comes up as category: unknown
Disconnect the USB cable..
Open the device manager...
Plug in the USB cable
see if you get the entry USB Printing Support under the menu
Universal serial Bus
if you don't see it replace the USb cable and try
On the Menu click on VIEW >>> Show hidden devices >>> try to find the USB print support
or the printers entry...
if you see it in some other category install the softwares
through the CD or get the drivers online through HP.com/support
it will work
if that does not work install the generic drivers
I.e open Printers&Faxes(XP), Devices&Printers(7)
click on add a printer
install a local printer
select the port as USB port
and follow the instructions
it will definetley recognize your printer
Happy Printing.....
Mar 04, 2011 | HP Officejet 6300
Is the steelseries 7h usb headset compatable with the ps3
Hello Sixlittledev,
Although the 7H USB headset is not natively supported by PS3, you may be able to get it to work if you have a headphone jack in your TV.
You will need to connect the headset in the following manner:
Headset microphone cable -> USB card -> PS3
Headset audio cable -> 3.5mm extension cable -> TV headphone jack
Although we do not guarantee compatibility and this method is a bit cumbersome, you can get it to work this way.
Mike S
SteelSeries Support
Http://www.steelseries.com/support
Dec 03, 2010 | Steel Series Steelseries 7H USB Headset...
Hi, I have targus usb to 232 serialcable , model
To use a pao88 on Win7 64bit you will need to have Win7 Ultimate, Professional or Enterprise edition AND your computers processor must support hardware virtualisation.
Dowload and install the latest version of XP Mode.
Install the cable in XP mode.
Turn on USB compatibility in XP mode.
Cable will now be accessable in Win7 64bit
I connected and ran a successfull diagnostic test on an old serial modem without issue.
Oct 27, 2010 | Targus (PA084U) Network Adapter
Printer P 400 not regonized by windows XP
check under device manager-universal serial bus controllers if you have USB PRINTING SUPPORT
-check for conflicts (?, !, X marks)
-If USB printing support doesnt show, unplug usb cable and try plugging cable to different usb port
-notify me after checking
Apr 05, 2008 | Office Equipment & Supplies
Computers & Internet Logo
53 people viewed this question
Ekse
Alun Cox
