Question about EliteGroup nForce3-A Motherboard
USB ports suddenly not functioning
Hi
I have a computer with ECS nforce3 1.0A motherboard. There are 4 usb ports on the mobo and I have 2 usb ports in front of the computer attached to the motherboard with cable. Some weeks ago I formatted the computer and re-installed win xp sp2. I believe everything worked fine after that (I have moved and not used the computer much during the move so I am not sure) but suddenly the usb ports do not work. The devices get power from them, but windows do not react at all. I have tried a wireless network card for usb, a printer and a usb pen. All the devices work on my laptop.
I have updated the BIOS, tried to uninstall the usb ports in device manager and reinstalled them. I also tried installing Vista to see if that helped, but nothing seems to do the trick. I would really appreciate any help here since this is driving me crazy.
  • Viper13 Apr 01, 2008
    Thank you, but all that is done, drivers are downloaded from ECS website (and tried the original on the CD), BIOS is checked and as far I can see there are no conflicts. There are however some devices sharing the IRQ with the USB. Not sure what, but it states "no conflicts".
    I am still grateful for suggestions.
  • vanxchazevna Apr 16, 2009
    port usb in my mobo doesn't work, if i plug printer, flashdik or anything else.. is not detected. NO RESPOND. it's s*ck
  • 242 Answers
I think installing the proper drivers for your motherboard and operating system should work.
Find your drivers here (scroll down to see the available drivers and make sure you install the drivers for your operating system) or on the cd that belongs to your motherboard.
Posted on Apr 01, 2008
    Problem Solver:
  • 7 Answers
Hi, see if you have installed any new devices/hardware to see if its conflicting, often grafics cards conflict usb devices, also just check that in the setup(when you boot up)that the usb ports have not been disabled or usb keyboard support hasn't been enabled/disabled. good luck!!
My front usb port on my pc are not working and how to fix it
If she shorted out the usb ports then you would want to replace the motherboard.
Dec 24, 2012 | Nvidia Ecs Mcp61m-m3 Geforce 6150se Socket...
Front panel USB connection
You have an ECS board and that is not enough info for us. We need to know the model number of it.
Nov 13, 2017 | ECS Computers & Internet
How to install a sd card reader on a Dell Dimension 8200 PC Desktop? no 4 pin usb on motherboard?
I managed to install a card reader on my Dell Dimension 8200.
The main problem is that the Dell motherboard does not have the correct USB pin. This is a 9-pin MoBo USB header.
The quick answer is I installed a USB card with an internal port.
http://www.amazon.co.uk/Unbranded-USB-2-0-PCI-Card/dp/B00066LPA2/ref=sr_1_6?ie=UTF8&s=electronics&qid=1264968643&sr=1-6
Secondly I reverse mounted a powered 4-port USB hub in the spare 3.5" bay.
http://www.cablecity.co.uk/product_info.php?products_id=1149&ref=6
Third, I purchased 2 USB 5 pin male to usb leads...
http://www.amazon.co.uk/v2-0-Male-Motherboard-Header-Connector/dp/B000QC7NKM/ref=cm_cr_pr_pb_t
You cannot buy a USB card with 2 internals and do away with the 4 port powered USB hub because the card reader does need to be connected to a powered USB port.
for more info see this...
http://www.mods-n-clocks.co.uk/?p=181
Jan 23, 2010 | Dell Dimension 8200 PC Desktop
Usb not recongised
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
The motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in. (VOILA)
Nov 28, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Tower top mounted USB portss
The cables from the front panel USB connectors have a key in them that will line up with the missing pin on the board's USB headers. Just line up the connectors and plug them onto the board. It doesn't matter if you use USB1 on the board for the plug marked USB1.
Apr 12, 2009 | Computers & Internet
741gx-m elitegroup motherboard, message''usg device not recognized
This is a USB problem. The pc is telling you that your device will work better if you connect it to a USB 2 port.
Make sure that you have your USB 2 drivers installed. They usually come on the setup disc that you have with your motherboard. If not, use free 'cpuz' program (google it) to determine your motherboard type/serial no, then search for 'usb 2 driver for 'insert your board serial' mobo.
Cheers
Apr 05, 2009 | EliteGroup MB ECS 741GX-M SIS741GX 462...
Front panel usb
Step 1: Decide weither you have one or two USB cables joined together, it should look like a 4 PIN header.
Step 2: Get your manual from ECS: http://www.ecs.com.tw/ECSWorldWide/Index.aspx?MenuID=0&LanID=9
Step 3: Install the 4 PIN header the right way +5V, - DATA, + DATA, GND on the motherboard, refer to the manual if you get stuck.
Oct 26, 2008 | EliteGroup ECS P4M800-M Socket...
PC Chips M957G MB. Can the 4 rear 4 USB ports easily be replaced?
hi there,
the rear USB port cannot be replaced, & glad that you still have a front USB connections into your MOBO..?
May i ask why did they suggest you to use the front USB panel..? Can you give us some info why this was happen..?
Thank you
May 27, 2008 | PC Chips M957G Motherboard
EliteGroup nForce3-A Motherboard Logo
246 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
