Question about Car Audio & Video
Oil warning light on a vw golf
Good morning,
Can you advise how I remove the warning oil light on my VW Golf 2001, Y reg please?
Thank you.
Katie Homer
SOURCE:
  • 225 Answers
SOURCE: engine service warning lights
You will need "VAG diagnostic software" - (google it) on a laptop and a £15 VAGCOM interface cable if you want to do it yourself.
Cheers, D.
Posted on Jul 10, 2008
  • 6 Answers
SOURCE: VW Golf Starting Problems
I HAVE THE EXACT PROBLEM!!! OK.. SO FINALLY AFTER A MONTH OF TRIAL AN ERROR.. I REPLACED THE COOLANT TEMP. SENSOR AND SERIOUSLY.. ALLLLL THE PROBLEMS WENT AWAY AND MY SYMPTOMS WERE IDENTICAL TO ALL 3 OF THE PEOPLE REPORTING THIS SAME PROB. ITS A $7.00 PART SO GRAB IT AND CHANGE IT.. IT IS VERY EASY TO SWITCH OUT AND I BET YOUR CAR RUNS AWESOME AGAIN :) GOODLUCK!! -MANDEY
Posted on Mar 17, 2009
SOURCE: vw golf est dashboard coil or spring shaped
was driving home this evening when my orange coil light started flashing what is this???
Posted on Aug 28, 2009
  • 305 Answers
SOURCE: vw golf tdi turbo problems
check the turbo hoses, they are renound for dry cracking, very hard to see at first glance
Posted on Sep 06, 2009
  • 1986 Answers
SOURCE: how to remove and repalce vw golf wing mirror
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you can remove the bolts securing the mirror to the door.
Posted on Sep 18, 2009
Good Morning - I did a emergency stop in my Golf GTI and the airbag fault light has appeared will I need to take my car to VW to be reset?
Anyplace can access the VW airbag code a reset might not do it. The reason for the light to come on is not beacuse you made a emergency stop.The light is warning you that a fault has been detected and if involved in a accident the air bag may not deploy or may deploy so theyll have find the code to see what has set it off.
Apr 24, 2011 | 2001 Volkswagen Golf
Where is the oil pressure sensor of vw golf 1999
The sensors are usually found on the oil filter flange housing with the oil cooler. Also there are two dynamic sensors to measure pressure below 2000 rpm and above 2000 rpm so it could warn you of pressure loss within those two ranges.
May 22, 2010 | 1999 Volkswagen Golf
Vw bora 1.6 s 52 reg emmisions warning light came on.
could be but i suspect the wires on the lambada sensor or the lambada has packed up`,get someone to plug it in and read the lambada temperature readings
Apr 20, 2010 | 1999 Volkswagen Golf
Where can i find the engine number
The engine number location depends on engine type.
1. For 2001 VW Golf 1.6 liters 16V engine:
2. For 2001 VW Golf 1.8 liters 20V engine:
3. For 2001 VW Golf 2.0 liters engine:
4. For 2001 VW Golf 2.3 liters engine:
5. For 2001 VW Golf 1.9 TDI-PD engine:
Feb 18, 2010 | 2001 Volkswagen Golf
I have this buzzing problem with my vw citi golf 1.4i
Not sure what model your car is,but try checking the two oil sender units,one located onthe side of the cylinder head[gearbox side]and the other on the oil filter housing.Also have a mechanic check oil pressure,should be+-2bar pressure at idle.If everything checks out,including the wiring,try another instrument cluster..Good luck
Jun 12, 2009 | 1998 Volkswagen Golf
VW GOLF MARK 4 Y REG
Hey mate i think your problem is the air flow mass sensor its a black box which its on to the big hose that gose in to you air filter it has a wire with a multiplug on it . you can disconect this then take ur car for little drive few miles and if the car is not being wore than it was before you need to go buy one quite expensive
Mar 04, 2009 | 2001 Volkswagen Golf
VW Golf 2001 Oil is emptying out
your cars engine piston rings are worn the engine is burning the oil the engine needs to be rebuilt
Dec 18, 2008 | 1986 Volkswagen Golf
Car Audio & Video Logo
312 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
