Question about HP LaserJet 1100 Printer
Printing becoming hard to read as words are fading especially the far right and far left of the page.
Toner catridge
Posted on Apr 05, 2008
  • 47 Answers
Looks like a problem with the toner or printer fuser assembly. Try shaking the toner for 30secs in left right direction and vice versa. If it works change the toner or refill it. Else, ask the printer technician to check up the printer hardware.
Posted on Apr 01, 2008
SOURCE:
When I print on my HP Color LaserJet 2600n Printer the far right(1 inch) of the page is faded and is unable to be read. I have replaced the ink cartridge but it doesn't help
Have you cleaned the print heads? There should be a program that came on the drivers disk that includes a "service" tab where you can align and/or clean the print heads automatically. If they are particularly dirty and have never been cleaned, you may have to run it through two cycles to get it right.
Oct 05, 2011 | HP Color LaserJet 2600n Printer
I have the hp 2640 half the right side of the page good but the left side is fain you can hardly see fade out form right to left side of the page
Most likely your print heads need to be cleaned. To do this go to start, devices and printers, right click on your printer and choose printing preferences, click on the color tab and at the bottom there will be an option that says printer services, click on this and click on clean cartridge. This should be all that you need to do! ;)
Oct 10, 2010 | HP LaserJet 2840 Printer
How to Add a Background Picture to a Microsoft Word Document 2007
t is easy to add a background picture by using the Watermark feature. First, you will click on “Page Layout”. In that menu bar (or ribbon), click on “Watermark”. A window menu will open. At the bottom of that window menu, click on “Custom Watermark”.
In the new menu that opens, check “Picture Watermark”, then “Select Picture” to find an image file on your computer to use. You have the option to have the picture look faded, as a watermark, or displayed in its full color. Check “Washout” for the faded option, or uncheck, to view the background picture in its full glory.
You will then need to choose the size of your background picture, by selecting one of the options under “Scale”.
To remove the watermark, simply click “Watermark”, and choose the “Remove Watermark” option.
Even if you don’t choose the “Washout” option, the background image will appear faded while you are working on your page. But, if you view the page through “Page Preview”, you can see how the background will look when printed.
To get to the "Page Preview" command, click on the button.jpgOffice Button on the upper left hand corner of the Word 2007 screen. Move your cursor over the "Print" option, and another menu will open to its right. On that menu, click "Print Preview".
Jul 21, 2010 | Microsoft Windows XP Professional With...
Lexmark C920 color print is faded on bottom of page
Quite possible something happened to the printheads.....especially the Magenta one. Might have been 'bumped' out of alignment. They might just need to be wiped clean with a toner cloth. They are usually right above the toner cartridges. Have you tried a color alignment adjustment in Config mode?
Mar 12, 2017 | Lexmark C920 Led Printer
Infoprint 1532 Faded txt on left half of page and normal on right
The problem is the transfer roller. If you remove the toner cartridge and look at the roller that is under it. It should be seated down. The gears should be on the left side. Try to remove it and replace it the correct way.
Jan 13, 2009 | IBM Infoprint 1352 Laser Printer
HP3600N color fade
It is using the colours to make the grey and the proportion is not correct. Do a calibration.
Dec 23, 2008 | HP LaserJet 3600n Printer
Fading on one side of the paper - Dell 1815dn laser MFP
The Printhead IS located above the toner cartridge on this model. There is a small opening that allows the laser light to shine through the case to the imaging unit on the toner, but you can not access the the laser without disassembling the printer.
Even though this is a new toner cartridge, it may be defective, even more likely if it is a non-Dell or remanufactured toner. Try reinstalling the old toner cartridge. Even if it prints light because it is low, if it is uniform across the page then the new toner is defective. Return or exchange it with the manufacture.
Sep 25, 2008 | Office Equipment & Supplies
Text becomes unreadable after one page of printing
model of the printer ? sound like a
heating device problem.
Aug 10, 2008 | Dell A920 InkJet Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Faded line going through
Anne, This could be several things-here is a list... 1. transfer roller or belt dirty, especially if inside of printer looks like it needs a cleaning. You could vacuum with toner vacuum or take it in for service. 2. scanner mirrors dirty. would need to be serviced by a technician. 3. scanner toner shield out of position-tech needed. 4. toner cartridge needs to be shaken horizontally-toner could be all on one side of hopper. 5. the fusing section could have work rollers, they sometimes get scored and leave a strange brownish line on the page that sort of fades if you print multiple pages. Again, tech would be needed. Anne, thanks and good luck.. Thanks and good luck...
May 11, 2007 | Dell 3100cn Laser Printer
HP LaserJet 1100 Printer Logo
63 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
